    Mover does not go
    11 Posts 7 Posters 2.5k Views 7 Watching
    • EdsonE Offline
      Edson
      I have tried to install mover.rba couple of times but not a thing happens. it does not show up in any menu; it is as if it was not there.
      I must surely be doing something wrong; the problem is to know what.
      I unzipped it and put the folder named mover Folder in the plugins folder of SU. inside that folder there is another named Jim Foltz which holds 3 more.
      could anyone tell me what I am doing wrong?
      cheers.
      http://www.mahfuz.arq.br
        You should have a script called 'JimFoltz.rb' in the Plugins folder that loads everything else...
        Inside the Plugins folder you should have a folder called 'JimFoltz'.
        Inside that you should have three sub-folders. These are called:
        'files' - containing 'mover.html'
        'images' - containing 6 jpg images for the buttons (e.g. 'arrow_blue_dn.jpg')
        'scripts' - containing 'mover.rb'
        THEN it will work and appear in the Plugins menu...
        • G Offline
          gksl4
          Is there a possibility you use SU5?
          Because (unfortunatelly) Mover.rb works only in SU6.
          Just a thought
          George
            Jim
            emahfuz,
            Please try the latest version: http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1530
            Thanks for your patience. It won't work with version 5 because it uses the new Webdialogs available in V6.
            I have tried to install mover.rb a couple of times but not a thing happens. it does not show up in any menu; it is as if it was not there.
            cheers.
            • EdsonE Offline
              Edson
              hi jim,
              i tried what you suggested and it worked beautifully.
              thanks.
              • EdsonE Offline
                Edson
                is there any important reason why it will not move an edge, a face or a construction line?
                • PixeroP Offline
                  Pixero
                  It only works with groups/components afaik.
                  I you're interested I have a script that is somewhat similar that lets you type in a distance value and move "anything" with the arrow keys. It's called jsMoveTool.rb
                  (www.pixero.com)
                    Jim
                    Is this a new post or an old post being transfered?
                      If you have a look at the post dates/times, it shows that it was transferred on Nov. 23 )within about two minutes ending with Edson's post after yours).
                      Then Edson went on with the discussion on Jan. 18 - so it must be "new" from that point.
                      • G Offline
                        gata
                        Nudge was the first script that used the arrow keys to nudge all sorts of stuff http://www.smustard.com/script/Nudge.
                        The Move Wizard in RpTools/Space Design also moves everything http://forums.renderplus.com/wiki/index.php?title=RpTools#Move_Wizard but works in PCs only.
                          Jim
                          I'm planning on trying a new move-like Tool that is keyboard only. I don't care for the dialog myself. I think with a well written instructions, intuitive functions, and using only keyboard with modifiers; a new mover could be a efficient tool.
                          I think I'll go try Jan's jsMoveTool now...
