    Mover does not go
    11 Posts 7 Posters 2.6k Views 7 Watching
    • EdsonE Offline
      Edson
      I have tried to install mover.rba couple of times but not a thing happens. it does not show up in any menu; it is as if it was not there.
      I must surely be doing something wrong; the problem is to know what.
      I unzipped it and put the folder named mover Folder in the plugins folder of SU. inside that folder there is another named Jim Foltz which holds 3 more.
      could anyone tell me what I am doing wrong?
      cheers.
      http://www.mahfuz.arq.br
        You should have a script called 'JimFoltz.rb' in the Plugins folder that loads everything else...
        Inside the Plugins folder you should have a folder called 'JimFoltz'.
        Inside that you should have three sub-folders. These are called:
        'files' - containing 'mover.html'
        'images' - containing 6 jpg images for the buttons (e.g. 'arrow_blue_dn.jpg')
        'scripts' - containing 'mover.rb'
        THEN it will work and appear in the Plugins menu...
          gksl4
          Is there a possibility you use SU5?
          Because (unfortunatelly) Mover.rb works only in SU6.
          Just a thought
          George
            Jim
            emahfuz,
            Please try the latest version: http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1530
            Thanks for your patience. It won't work with version 5 because it uses the new Webdialogs available in V6.
            I have tried to install mover.rb a couple of times but not a thing happens. it does not show up in any menu; it is as if it was not there.
            cheers.
            • EdsonE Offline
              Edson
              hi jim,
              i tried what you suggested and it worked beautifully.
              thanks.
              • EdsonE Offline
                Edson
                is there any important reason why it will not move an edge, a face or a construction line?
                • PixeroP Offline
                  Pixero
                  It only works with groups/components afaik.
                  I you're interested I have a script that is somewhat similar that lets you type in a distance value and move "anything" with the arrow keys. It's called jsMoveTool.rb
                  No website is present on this hostname
                  The website you are trying to reach could be suspended, deleted or DNS could be incorrect
                  (www.pixero.com)
                    Jim
                    Is this a new post or an old post being transfered?
                      If you have a look at the post dates/times, it shows that it was transferred on Nov. 23 )within about two minutes ending with Edson's post after yours).
                      Then Edson went on with the discussion on Jan. 18 - so it must be "new" from that point.
                        gata
                        Nudge was the first script that used the arrow keys to nudge all sorts of stuff http://www.smustard.com/script/Nudge.
                        The Move Wizard in RpTools/Space Design also moves everything http://forums.renderplus.com/wiki/index.php?title=RpTools#Move_Wizard but works in PCs only.
                          Jim
                          I'm planning on trying a new move-like Tool that is keyboard only. I don't care for the dialog myself. I think with a well written instructions, intuitive functions, and using only keyboard with modifiers; a new mover could be a efficient tool.
                          I think I'll go try Jan's jsMoveTool now...
