    I am unable to download CameraKeyMaker
    4 Posts 3 Posters 197 Views 4 Watching
    • H Offline
      harishkharai Newcomers
      Re: [Plugin] CameraKeyMaker 1.0 (Update 2011-04-09)
      TIGT 1 Reply Last reply Reply Quote 0
        TIG Moderator @harishkharai
        @harishkharai
        On checking I see that although it's available in the PluginStore it won't download.
        The ExtensionStore dialog also hangs installing it.
        Perhaps @rich-o-brien or @Gábor can help...
          SketchUp Plugins | PluginStore | SketchUcation
          SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
          (sketchucation.com)
          Downloads for me at this link and it installs using Sketchucation Tools
          It is not compatible with newer versions of SU though.
          @TIG can we fix this? see below
            @harishkharai I fixed the URLs in the original post so it points to the correct download locations
            You need to install the Google Bezier plugin for this to work correctly. I also linked to that in the post.
            This plugin generates smooth animations based on a camera path (bezier spline). Camera keys are editable and saved within the drawing. How to install: First ...
            sketchucation (community.sketchucation.com)
            @tig Ignore my 'doesn't work'. It does when setup correctly
