    Scene animation with Animator
    Scheduled Pinned Locked Moved Animator Beta
    107 Posts 3 Posters 16.9k Views 3 Watching
    • fredo6F Offline
      fredo6
      I tested your Camera Positioing 6 model. No error and I can set any view.
      However, since I don't know what you want to achieve, it's difficult to help....
      • ntxdaveN Offline
        ntxdave @fredo6
        @fredo6 Which camera tool are you using?
        I have tried both types and I seem to be getting scene views instead of the current screen shot.
        Press F1...thank me later
        • fredo6F Offline
          fredo6
          I am using Static View
          • ntxdaveN Offline
            ntxdave
            OK - I went back to the 6 file and got everything to work fine.
            Now, this file is closer to where I am trying to go but I am having several problems with it. Hope you can straighten me out.
            Camera Positioning 5.skp
            • ntxdaveN Offline
              ntxdave
              OK, I had everything working in the Camer Positioning 6 file so I copied it and tried rearranging some things. In particular, I tried moving the Box One scene and camera capture to the beginning and it through everything off. So, I am becoming more confused as to what my "rules" need to be. Maybe I need to just do the object movement portion in Animator and do the "other stuff" in a video editor (which is something @rich-o-brien had suggested).
              Am I being unrealistic as to the type of stuff I should do with Animator?
                Rich O Brien Moderator @ntxdave
                @ntxdave said in Scene animation with Animator:
                Horses for courses.
                Do whatever makes you happy...πŸ˜€
                Animator is primarily a tool to animate objects in SketchUp.
                That doesn't mean it can't do other things.
                I think you need to spend time learning it
                • ntxdaveN Offline
                  ntxdave @Rich O Brien
                  @Rich-O-Brien said in Scene animation with Animator:
                  Horses for courses.
                  I have been doing a lot to learn it (IMO), also @fredo6 has been working with me. He even found a bug related to one of the first files I shared and created an update which resolved the problem. know I am getting old and do not use SketchUp as much as I used to. But it seems that some of the issues I am having are more related to some things I am doing in native SketchUp rather than Animator.
                  If I do some of the stuff I want to do in addition to the Animator animation, I still need to find another product (video editor) that I can afford ( or free). All of this is for my enjoyment/pleasure. As we age (at least some of us) do things like this for pleasure/hobby and unfortunately cost does become a factor.
                  Even though this has been a little frustrating and a learning challenge, I want to continue and want people like you to not give up on me. Even though I still cannot get everything to work (as of now) the things I have learned have been fun. πŸ˜€πŸ˜€πŸ˜€
                    That maybe true. You just need to persevere. I would hold the belief you need a good foundation on using SketchUp to really getting the most from Animator.
                    If you knowledge level in SketchUp is low that is easy fix. Model, model and model.
                    • ntxdaveN Offline
                      OK, I think I am learning and I keep working on learning more things. Now back to this subject. I am sharing the animator animation that has led me to all of this. This is the model that inspired me to get more involved with Animator. I hope you see it as a step forward. I know it is pretty basic but it where I want to start. Now I want to see if I can figure out a way to add two text scenes. One at the beginning that gives some insight to what the model/animation is all about and the second text scene will be to give some information about the model/animation.
                      Here is the file for you to download/view to get some insight about where I am headed.
                      Learning Animator Animation.skp
                      Yes, I know I could have saved the movements as a clip but did not do it yet. I also thought there should have been an animator file but did not see it to download.
                      • ntxdaveN Offline
                        ntxdave
                        OK, as part of my β€œlearning” experience, I have been trying to figure out a way to add a new scene that would have the β€œintroduction” or β€œconclusion” text (and possibly some other things to animate) and cannot get things to work. In the file i shared/posted before the items that are animated were created in a front scene scene. I tried putting way far away on a front view and the new stuff (again way far away) in a top view. I also used tags/layers for each of them so that you should only see what is visible tied to the scene (hope this makes sense) but when I try to transition to the new scene you see the stuff that is supposed to be hidden. I have tried bit of the camera options (current view and scene view) and the results are pretty much the same. When you go from one view/scene to the other you see the stuff that is supposed to be hidden (although from the new view).
                        I hope this explanation makes sense and someone can give me a way to solve this, if there really is a way to resolve it. I have tried bit of β€œmany” ways to figure this out. 😩
                        • fredo6F Offline
                          fredo6
                          Again, text drawing would be better managed in a video editor rather than Animator.
                          If your text is a solid, just treat it like that. Insert Movement (Move, Rotation) in the timeline. Use special effect Visibility to make it appear and disappear (via its tag).
                          Cameras are independent from object movements.
                          • ntxdaveN Offline
                            ntxdave @fredo6
                            @fredo6 said in Scene animation with Animator:
                            That is what I have been thinking but I have not found software to use. I was thinking I might have some text or other objects I might want to animate as part of the β€œintroduction” or β€œconclusion” though.
                            That is what I have been trying.
                            Yes, I understand. However, what I was trying to achieve (or would like to) is to get basically the same result as if when you are looking at your model and clicking on each scene tab but with animations added.
                            Again, hope that clarifies what I was trying to achieve.
                            • ntxdaveN Offline
                              ntxdave @ntxdave
                              BTW: Just curious if anyone looked at the file I posted before and has any suggestions.
                              • ntxdaveN Offline
                                ntxdave
                                Hope someone can tell me what I am doing wrong.
                                SketchUp file I used for the movie:
                                Camera and Animations.skp
                                Here is the movie that was produced by Animator. Camera and Animations.mp4
                                So if you download the SketchUp file and then click on each of the scene tabs and compare that to what was generated by Animator, I have the following comments/questions:
                                • On each of the scenes, there should be text that tells which scene you are viewing.
                                • On each of the scenes, there should be an object (one that I wanted to add a motion to later)
                                • The text on each of the scenes is controlled by a tag/layer which Animator seems to be ignoring.
                                • The object (that I wanted to animate) on each of the scenes is also controlled by a tag/layer which Animator seems to be ignoring
                                • I used the tag/layer visibility controller for all of the movie. However, I have to admit that I added that feature as the last item. Should I have done that before taking the pictures?
                                • You will notice that for each of the scenes I used the camera option to use the scene. I have also tried doing the whole thing with the current view option for capturing the camera. But I got the same results when trying that way.
                                Again, am I doing something wrong?
                                What I would like for Animator to do is give me the same results as if you click on the scene tabs one at a time and the transition in Animator would be the same as it happens in native SketchUp. @fredo6 is that possible? If so, this would give me (I think) the capability I have been trying to achieve.
                                • ntxdaveN Offline
                                  ntxdave
                                  OK, after some more β€œlearning” and trying to understand, I think I have figured out what is going on and wonder if there is a way to resolve it.
                                  I started the model in the example by creating a 3D box. I then added a color to each of the faces. The I started adding text and other objects as parts of scenes. If you look at it, I added the β€œface” name to the front, right, left and back of the 3D box. So, as an example, I created a scene named β€œFront” using the front face of the 3D box. I then added other items and assigned a tag/layer to the text and other objects. I then used this same approach for the other views.
                                  Now when I add a camera in Animator, I used the name of the scene and all seemed to go well until I try move through the β€œscenes” itfinallt dawned on me is that when I go from one scene to another it is (I think) using the face side of the 3D box to control what is being shown. As an example, when it goes from, say front, to right, it is using the SketchUp camera setting to navigate between the scenes. Thus it rotates the 3D box to the camera view that I used to create the scene but no applying the tag/layer setting the matches the scene settings.
                                  I hope this description makes sense. In other words, IMO, the script is using the SketchUp face view orientation instead of the scene settings. Again, I hope this makes sense.
                                  • ntxdaveN Offline
                                    ntxdave
                                    OK, I think I am making some progress/learning. Here is my latest video. Visibility Test.mp4
                                    I realize this is not very complicated but during the development process, I think I have learned some new things about how to do some things. Now I want to try to combine this with something in another scene so that I can have two scenes in a model that combines capabilities like this. At the rate I am going/earning though, this will probably not happen for a couple of days.
                                      But what you learn is permanent. That is why I advocate for people to stay the course and troubleshoot themselves.
                                      Plus you get a dopamine hit every time you figure stuff out. Getting spoon fed answers has the opposite effect.
                                      • ntxdaveN Offline
                                        Thanks @rich-o-brien πŸ‘πŸ‘ Don’t give up on me
                                        I am going to figure this stuff out. I think from what I learned today (by first looking at an old video and file that I did a few years ago) and the applying some of the same things (primarily the visibility feature). When I get back to this, I want to try the following:
                                        • Save what I have done so far as a clip
                                        • Create a second scene that has some similar features as the existing one (visibility and animation)
                                        • Possibily, but maybe not right away, camera positioning.
                                        Again, thanks for the response and if I have offended @fredo6 in any way i apologize. I am going to figure this stuff out and learn how to take full advantage of the features/capabilities of Animator. IMO it is a great tool that has a lot of power that I hope I can use for some things I would like to and, hopefully, help others see. πŸ˜€πŸ˜€πŸ˜€
                                        • ntxdaveN Offline
                                          ntxdave
                                          Again, more progress. As it turns out, I think the problem I was having in the past was not a problem with Animator but rather my lack of understanding of how to use the Visibility tool. Well, I think I have worked it out (still more to learn but definitely making progress). Here is my latest video that includes the use of scenes, camera positions/views, and animations in a scene. While there are some awkward movements, the bottom line is that I was able to accomplish what I was attempting to do. I was able to capture each scene and its movements into a clip. I am sharing the video to let you see that I am moving forward. πŸ˜€
                                          Camera and Animation.mp4
                                          Now for a couple of final questions/comments:
                                          • Is there some place where I can learn more about the visibility tool. In particular, when you look at the various options as I have pointed out in this image. Visility Tool.png
                                          • I think with what I have finally learned, that my idea of an Animator video of an animated model with an introduction scene an animation scene, and a conclusion scene is completely possible. 😁 πŸ‘ πŸ‘
                                          As always, I would appreciate any comments and I really want to thank both @rich-o-brien and @fredo6 for their patience and the feedback they have given me up to this point. πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                                            Not really. Just experiment. Most are default SketchUp features reimagined to be used in an animation scenario. Hover for tooltips.
                                            • 6
                                            • 4 / 6
