    Create new or adjust materials
    21 Posts 4 Posters 195 Views 4 Watching
      Sometimes it's easier to start 2D flat and progress to 3D then add gentle deformations...
      With the 'crude' form you can then let SUbD do the heaving lifting.
      But, like your other thread this is now unrelated to creating materials.
      My advice to practice, make mistakes, try fix them yourself and rinse repeat.
      • ntxdaveN Offline
        ntxdave
        Yes, once agin I have gone of track. Seems to be a pattern lately.
        I had drawn a heart recently but when I tried it again (several times) it did not come out good. I will keep trying though. 😠. I will figure it out. Wish I could afford SubD.
        • ntxdaveN Offline
          ntxdave @ntxdave
          Making some progress πŸ‘ πŸ‘ πŸ‘
          • ntxdaveN Offline
            ntxdave
            OK guys, I am having some more problems. If you look at the image below, I think I have outlined my problems.
            Yes @rich-o-brien I do have an F1 key but I am having some new problems. I hope someone can give me some pointers.
            • ntxdaveN ntxdave referenced this topic
              sashapepperspray
              did you by any chance press k on the keyboard, it looks like back edges are showing
                Dave R @ntxdave
                This post is deleted!
                  You appear to have Back Edges turned on. K is the default keyboard short. Tap it and the Back Edges should turn off.
                  Are you rotating the object or orbiting the camera?
                  @ntxdave said in Create new or adjust materials:
                  What problems? F1 is a hard coded shortcut so you can change that one.
                  • ntxdaveN Offline
                    ntxdave @sashapepperspray
                    @sashapepperspray said in Create new or adjust materials:
                    Not sure what you are asking about the K key.
                    • ntxdaveN Offline
                      ntxdave @Dave R
                      @Dave-R said in Create new or adjust materials:
                      I will give that a try the next time I start up my laptop. Is that for the heart or the other objects? I have been having a little problem trying to place the 3D text at the right Z level.
                      I was rotating the and I also orbited the camera,
                      That was kind of a joke between me and @rich-o-brien .
                      • ntxdaveN Offline
                        ntxdave @ntxdave
                        OK guys (@dave-r and @sashapepperspray), I went and got my laptop and fired up the model. I clicked on the heart object and then clicked on the K key. Guess you guys were right. I can no longer see the text through the model.
                        The only problem I am having now is that when I rotate the object (actually the camera), the image on the back side of the heart comes and goes. I guess I need to make that a separate object instead of pasting the image to the back surface of the heart.
                        Gave it a go and all seems to be OK now.
                        After all the years I have been using SketchUp, I am surprised and embarrassed by the stupid mistakes I have been making lately.
                          Dave R @ntxdave
                          So you mean orbit the camera?
                          Sounds like Z-fighing. Make the image of the heart a texture and apply it to just the back face of the heart. Turn on Hidden Geometry so you can paint the back separately from the rest.
                          • 2 / 2
