    SketchUcation Tools v5.0 Error in SketchUp 2025 – NoMethodError split for nil:NilClass
    11 Posts 2 Posters 1.4k Views 2 Watching
      daydreamdesign Newcomers
      Hello,
      I was trying to download and install the new SketchUcation Tools update (v5.0) for SketchUp 2025. Before installing, I deleted and uninstalled all older SketchUcation files to make it a clean install. I followed instructions and ran the installer/repair as Administrator, and I also performed a full cold boot of my PC.
      Unfortunately, the issue persists—I’m still getting the same extension errors with SketchUcation. Now, whenever I install, open, or refresh the plugin, I encounter the following error:
      Extension Errors Report
      SketchUp: 25.0.660
      OS: Windows 11
      Ruby: 3.2.2
      Extension: SketchUcation (5.0.0)
      Error: NoMethodError (undefined method split' for nil:NilClass) c:/users/daydr/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:770:in block (2 levels) in getMyPlugins’ c:/users/daydr/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:753:in each'
      c:/users/daydr/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:753:in block in getMyPlugins’
      c:/users/daydr/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:751:in `each'
      c:/users/daydr/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scf_dialog.rbe:751:in getMyPlugins’
      c:/users/daydr/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins/sketchucation/scf_loader.rbe:99:in module:SCF
      I’m not sure what to try next. Has anyone else encountered this issue, or is there a recommended fix? Any guidance would be greatly appreciated.
      Thank you!
      TIGT 1 Reply Last reply Reply Quote 0
        TIG Moderator @daydreamdesign
        @daydreamdesign
        Something is going adrift with the code being able to get an extension's versions.
        This then causes the error.
        Can you do the following and copy/paste the results in a reply.
        Open the Ruby Console [Extensions > Developer submenu item].
        Copy paste this code and press enter...
        puts SCF_Dialog.getMyPluginsFolders;
        puts "\n___\n\n#{Sketchup.read_default("SCF", "DefaultPlugins", "?")}\n\n";
        Sketchup.extensions.each{|ex| puts "#{ex.name} = #{ex.version}\n" };
        puts "\n___\n";
        It might show up some unexpected errors...
          Here is the results:
          Planar Lock = 1.0
          => nil
            @daydreamdesign
            Sorry, but that is not the message ! Or if it is it's not the whole thing.
            Please follow the instructions again and post the resultant output.
            This should consist of:
            1. a number of possible Plugins folders paths/names, inside []
            2. the default Plugins folder path/name
            3. a list of several lines - 'extension_name = version'
              I didn’t scroll up! I’m sorry, here are the correct results:
              puts "\n___\n";
              C:/Users/daydr/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins
              C:/ProgramData/SketchUp/SketchUp 2025/SketchUp/Plugins
              3DxSketchUp = 5.7.1
              1001bit tools = freeware_1.0.5
              2Dtools = 7.7
              3D Bazaar = 1.0.1
              Architextures = 1.1.2254
              Convert to Conststruction Line = 1.0.1
              PlaceMaker = 3.3.3
              Profile Builder 4 = 4.0.4
              Quantifier Pro = 1.2.4
              SketchPlus = 1.3.0
              SketchUV = 1.0.2
              Artisan 2 = 2.1.2
              ExtrudeTools = 5.0
              Fredo6 LibFredo6 = 15.3a - 02 Apr 25
              Fredo6 Animator = 4.3d - 17 Mar 25
              Fredo6 Curviloft = 2.0a - 31 Mar 24
              Fredo6 Curvizard = 2.5a - 01 Apr 24
              Fredo6 Fredo Corner = 2.7a - 31 Mar 24
              Fredo6 FredoPortrait = 2.9a - 01 Apr 24
              Fredo6 FredoScale = 3.6a - 01 Apr 24
              Fredo6 FredoSpline = 2.6a - 01 Apr 24
              Fredo6 Fredo Tools = 4.5c - 24 Jun 24
              Fredo6 JointPushPull = 4.8a - 30 Mar 24
              Fredo6 ThruPaint = 2.8b - 20 Dec 24
              Fredo6 Tools on Surface = 2.6a - 01 Apr 24
              Fredo6 TopoShaper = 2.7a - 01 Apr 24
              Fredo6 VisuHole = 1.5a - 01 Apr 24
              InstantArchitecture =
              Material Resizer = 1.0
              SketchUcation = 5.0.0
              Soap Skin & Bubble = 1.0.35
              TT_Lib² = 2.15.1
              QuadFace Tools = 1.0.0
              Voronoi + Conic = 2.2
              JHS_Powerbar = Feb 2018b
              Ruby Console+ = 3.2.0
              Unwrap and Flatten Faces = 2.6
              Random Tools = 1.4
              BezierSpline = 2.2a - 22 Apr 21
              Dialog = 1.0
              CLF Component Stringer = 1.3.1
              Point Gadget v2.5 = 2.5
              Curic Face Array = 0.7.1-yagi
              Curic Mirror = 1.4.0
              Curic Zoom Through = 1.0.0
              Eneroth Face Creator = 1.0.0
              Eneroth Flatten to Plane = 1.1.0
              Eneroth Fractal Terrain Eroder = 1.1.0
              Eneroth Solid Tools = 3.0.1
              Eneroth Terrain Volume = 1.0.0
              Engineering ToolBox = 1.0.5
              Estimator = 2.0
              FlexTools = 2.17.0
              Add Location = 1.7.8
              Lightbeans Textures Library = 1.1.6
              RubysketchScaleTool = v1.0.0
              s4u-Slice = 5.2.2
              s4u-Components = 7.2.1
              3skeng Engineering 2025 = 2025.3.x.xxx
              ShootPlantPlanner® = 2.0.4
              Skatter = 2.2.1
              STL Import & Export = 2.2.0
              DropGC = 1.0.3
              PathCopy = 2.2.0
              Weld = 3.0.1
              SketchUp Diffusion = 1.2025.09.10
              Dynamic Components = 1.8.3
              Migrate Extensions = 1.0.0
              Sandbox Tools = 2.3.5
              Simplify Contours Tool = 1.1.2
              AIM for SketchUp = 1.0.0
              Architect Tools = 2.1.2
              CleanUp³ = 3.4.6
              Edge Tools² = 2.2.0
              Groups to Components = 1.1.0
              Material Replacer = 1.2.0
              Material Tools = 2.7.2
              Component Replacer = 1.1.0
              Selection Toys = 2.4.0
              Vertex Tools² = 2.0.13
              Universal Importer = 1.2.6
              Bulge = 1.0
              Push = 1.0
              Smooth = 1.0
              Smudge = 1.0
              Grab = 1.0
              Planar Lock = 1.0
              => nil
                If you follow the file address you can see I have the 5.0 file in the file for SketchUcation.
                  The culprit is "InstantArchitecture = " which does not have a version set up properly!
                  Our code assumes some version for every extension, even if it's blank "" - but yours is 'nil'.
                  We can add code to trap for this rare anomaly.
                  After exhaustive pre-release testing this is the first report like this.
                  This update might not be published for a while, so in the meanwhile try these fixes.
                  Disable 'InstantArchitecture' in the Extension Manager [or our Plugins Manager] and restart SketchUp -
                  our ExtensionStore should then work OK.
                  Alternatively, get an update from the author which has a proper version set and install that and restart SketchUp.
                  Or edit its register file in the Plugins folder [InstantArchitecture.rb] with Notepad++ or another plain-text editor - add a line saying VERSION = '0'
                  Save and restart SketchUp, as it's version is now set to '0' the ExtensionStore error will stop.
                  Where did you get this extension from ? It's not listed in our PluginStore. In the Extension Warehouse 'Instant Architecture' by Chuck Vali has no version listed so I guess that's the one... As its subscription only from his site I don't know the exact code structure, the VERSION = '0' fix won't break anything in the code provided that you have your Extension Manager's Loading Policy set to Unrestricted [if it's signed] - after checking it that extension is ignored anyway as it's not in our Store so is not checked for an update, which is impossible with the versioning it has anyway...
                  D 1 Reply Last reply Reply Quote 0
                    v5.0.1 is now available in our ExtensionStore.
                    It traps for the earlier error, which resulted from your loading-extension not having a valid version set up.
                    https://sketchucation.com/pluginstore?pln=SketchUcationTools
                      daydreamdesign Newcomers @TIG
                      @TIG Yes sir, I will try this.
                        It worked! I had to uninstall the Vali Architects Instant Architects plugin, and boom, everything started working! Wow, for you to spot that is a blessing.
                          Our v5.0.1 is now published in the ExtensionStore.
                          This traps for sloppy extension creation without a version being set.
                          After you install that you can restart SketchUp, and then restart using InstantArchitecture without any clashes...
