    [Plugin] LayOps - v1.3a - 18 Dec 25 (Dual Dimensions in Layout)
    8 Posts 4 Posters 922 Views 4 Watching
    • fredo6F
      fredo6
      The information on LayOps is maintained on the Plugin Home Page of LayOps. This is also where you can download the RBZ file.
      • LibFredo6: v15.6a or above
      • Sketchup version: SU2018 and above
      • Usage: Licensed under Sketchucation SCFLicense as of 01 Sep 25
        • Free Trial period (full features): 30 days from activation
        • Perpetual license (3 seats): $15
      If you land on this page and are unfamiliar with how to install Sketchup Extensions such as LibFredo6 or how to register on Sketchucation, please watch this video or refer to the Plugin page of LibFredo6.
      LayOps generates a copy of a Layout document with some transformations. The first transformation published is about Dimensions, in particular Dual Dimensions.
      The process is as follows:
      1. Select the original Layout document. This document will not be touched by the process.
      2. Choose options for specifying the path of the generated Layout document as well as the unit system for the dimensions and the type of transformation (dual units or substitution of units).
      3. The new Layout document is generated
      IMPORTANT: The generated document is a copy of your original document with the requested changes of dimensions. You are NOT SUPPOSED to work on the generated document; the main reason is that the dimensions (dual or substituted) may no longer be auto-text. Everytime you make a change to the original document, you may want to regenerate the document with the change of dimensions. This is fast and automated.
      No documentation for the time being. Please watch the video
      Overview of LayOps dimensions
      Reply Quote 2
        Very clever tool. Thanks Fredo
        • fredo6F
          fredo6
          NEW RELEASE: LayOps v1.2a - 14 May 25
          Requirements:
          • >= LibFredo6 15.4a
          LyOps 1.2a is a release including:
          • Functional adjustment (keep auto-text whenever possible)
          Home Page of LayOps for information and Download.
          Main post of this thread.
            Very nice update. Thank you!
            • fredo6F
              fredo6
              NEW RELEASE: LayOps v1.2b - 14 May 25
              Requirements:
              LyOps 1.2b is a release including:
              • Functional adjustment (keep auto-text in most situations, except when using hyphens)
              • fredo6F
                fredo6
                NEW RELEASE: LayOps v1.3a - 18 Dec 25
                Requirements:
                • >= LibFredo6 15.6a
                LayOps 1.3a is a release including:
                • Extension of validity
                • G
                  Gberto88 Newcomers
                  I am trying to use the LayOps with sketchup 2027 is it compatible?
                  I did purchase the plugin but dont have the contact support, any help will be appreciated it
                  fredo6F 1 Reply Last reply
                  • fredo6F
                    fredo6 @Gberto88
                    @Gberto88
                    It should be. Do you have any issue?
