    SimpleRotate - Rotate objects along X/Y/Z by ±90°
    13 Posts 3 Posters 933 Views 3 Watching
    • P Offline
      pencilimage Newcomers
      Hello,
      This is a minimalistic plugin to rotate groups/components in SketchUp by ±90° along the X, Y, or Z axis.
      Features:
      Rotate selected objects by ±90° (X/Y/Z)
      Toolbar with axis-specific buttons
      Optional custom input for arbitrary angle and axis
      This plugin adds a menu item to the Extensions menu.
      You can also assign a shortcut key from SketchUp's Preferences.
      Installation:
      Download the .rbz file below
      In SketchUp, go to Window > Extension Manager > Install Extension
      Select the SimpleRotate.rbz file
      Done! You’ll see the toolbar and menu under Extensions > SimpleRotate
      Compatibility:
      Tested on SketchUp 2022–2024 for Windows
      Author:
      pencilimage
      © 2025 pencilimage. All rights reserved.
      Download:
      simple_rotate_stable_final.rbz
      massimoM 1 Reply Last reply Reply Quote 0
      • massimoM Offline
        massimo Moderator @pencilimage
        Thanks. It works in SU 2014 too.👍
        • P Offline
          pencilimage Newcomers @massimo
          Thank you for your comment!
          I'm glad to hear that it works in SU 2014!
            cool script, want to add it our ExtensionStore?
            • P Offline
              pencilimage Newcomers @Rich O Brien
              @Rich-O-Brien
              Thank you for your kind offer!
              I'm interested. Could you please tell me how to proceed?
              massimoM Rich O BrienR 2 Replies Last reply Reply Quote 0
              • massimoM Offline
                @pencilimage Btw, how about adding a button that can do what you see at the end of the GIF?
                Here I use my own tool that I made long time ago simply "packaging" a two lines code posted here somewhere by someone.
                P 1 Reply Last reply Reply Quote 1
                • P Offline
                  @massimo
                  Thank you for your suggestion.
                  I understand that you are proposing to add a button to move selected objects to the origin, as shown at the end of the GIF.
                  It's a very interesting idea.
                  I will consider whether to add a new button or integrate it into the existing tool.
                  Thank you again for your advice.😊
                  • massimoM Offline
                    massimo Moderator
                    Well, not necessarily to the origin. What I mean is to bring the object back to be oriented according to the global axes.
                    P 2 Replies Last reply Reply Quote 0
                    • P Offline
                      @massimo
                      I understand what you mean. I'll think about it. Thank you!
                        Rich O Brien Moderator @pencilimage
                        @pencilimage
                        If you logout and then vit sketchucation.com and login you should see Dev Tools in the header of the site.
                        Have a poke around there. New extensions uploaded need approval so don't be concerned if you don't see it immediately.
                        Any queries you can ask here or email support@sketchucation.com
                        • P Offline
                          @Rich-O-Brien
                          Thank you very much for your kind message.
                          I’m planning to review my plugin a little, so it may take some more time, but I hope to give it a try in the near future😊
                          • P Offline
                            @massimo
                            I realized it’s difficult for me to add that function to the current plugin.
                            I’ll consider making a simple separate plugin instead.
                            Thank you!
                            • massimoM Offline
                              @pencilimage Don't worry, it was just a suggestion. 😉
                              The plugin is already very cool as it is.
