    Seamless tiling
    5 Posts 4 Posters 988 Views 4 Watching
    • Epix3DE
      Epix3D
      Trying to make a seamless texture. When used in SketchUp 2025 it tiles wrong.
      Anybody have a solution?
      • TIGT
        The joints need to be whole or a half [or zero]. At the moment the short lengths of joint don't add up to a whole joint, hence the oddity when the texture repeats.
          It tiles correctly in SketchUp for the image you have supplied.
          Illustrating what TIG described: I cropped your image down to eliminate the partial tiles on the sides. The cropped image is shown imported as an image on the left and as a material on the larger face to the right.
          panixiaP 1 Reply Last reply
          Reply Quote 3
          • panixiaP
            panixia @Dave R
            @Dave-R I would recommend to crop such kind of "self repeating" texture into a single tile, so that it weights about 50 times less for the same quality.
            Unless you need to add some variation on top of that, of course.
            Dave RD 1 Reply Last reply
              Dave R @panixia
              @panixia that's fine. I was simply demonstrating what it would take for the OP to use the texture image they shared.
