    SketchUp 2025. The styles toolbar disappears every time I close it.
    5 Posts 4 Posters 1.1k Views 4 Watching
    • alexpacio2013A Offline
      alexpacio2013
      I have a problem with SketchUp 2025 that I can’t solve. Basically, every time I open SketchUp 2025, it doesn’t display the styles toolbar. I always have to open it every time, and once I’ve completed a task, I close, save, and reopen SketchUp, and it’s always the same issue. What can I do?![alt text]SketchUp_0K4TOKjQE2.png
        Things like forgotten toolbars etc are a sign that preferences aren't getting saved - usually because preference files don't have the correct permissions.
        This is usually because SketchUp wasn't installed properly [on Windows]. This can be fixed without having to reinstall SketchUp, do this...
        Close SketchUp
        Find its installer exe file - usually in your Downloads folder [or get another copy]
        Select that exe file's icon, right-click > context-menu > Run as administrator...
        In the dialog which opens choose 'Repair'.
        When it's done restart SketchUp and arrange your toolbars as desired.
        Close SketchUp.
        Open SketchUp - is there any improvement is the remembering of preferences ?
        Other things like installed extensions should be unaffected.
        Double-clicking an installer's exe file to 'Run' it is not the same as doing it as outlined above - even if your user-account has admin-powers...
          alexpacio2013
          Thanks I solved it, I didn't understand why only that bar didn't work, anyway with the repair as administrator it solved it
            roximate Newcomers
            My SketchUp installer is corrupted; can I repair it another way?
            panixiaP 1 Reply Last reply Reply Quote 0
            • panixiaP Offline
              panixia @roximate
              @roximate maybe just move it to the bin and download a new one from scratch?
