    Fredo Animator
    6 Posts 3 Posters 496 Views 3 Watching
    • J
      jonorman
      Anyone know whats going on here ?? The arm is a component with several subcomponents in a "logical order"
      the cube is a standalone component. When trying to pick up the cube by "Ctrl" clicking on the cube and rotating it with the arm it just flies away.SketchUp_93GtOIcnnm.gif
        Sometimes the transformation will be inferred off the hovered object.
        If you hover the timeline elements you can see info related to where the object is transforming from.
        It can get a bit confusing with nested groups. But hovering the elements will display info related to what is happening.
        • fredo6F
          fredo6
          Do not select the arm and the cube together for the rotation (because the arm has other rotations).
          • J
            jonorman
            So the answer here is to have the "pickup and rotation" done in two paralell actions, with the same pivit point ?
            • fredo6F
              fredo6
              Yes. It's safer, because the arm and the cube have different path before. Linking them together in one movement make them dependent for all movements
              • J
                jonorman
                Ok, makes sense. Thank you πŸ™‚
