    Image Trimmer problem
    2 Posts 2 Posters 189 Views 2 Watching
    • Z
      ZG53 Newcomers
      I have a problem with Image Trimmer. When I do everything right, including importing the image (png file) and saving it, when I start I,mage Trimmer , WinRar opens a window with EdgeDetector.jar. Image Trimer does nothing. What is the problem? Everything runs on an AMD Ryzen5 processor with 16 Gb of RAM. with Sketchup 2022.
      TIGT 1 Reply Last reply
      • TIGT
        TIG Moderator @ZG53
        @ZG53
        If you read all of the thread and the guidance notes...
        The JAR files that ImageTrimmer uses must run/open in Java.
        So firstly you need to have Java installed [if you don't already have it, the it's freely available off the www...].
        Next you must ensure that the JAR files are set to open with Java, many unZIP/decompression tools like WinRar hijack that file type and open it themselves [uselessly]. Go into the associated filetypes in WinRar and untick .JAR...
        ImageTrimmer should now run as intended, although to do need to ensure it's working on a PNG file Image with fully solid and transparent areas...
