    FredoJointPushPull-v4.8a error
    7 Posts 5 Posters 481 Views 5 Watching
    • A
      aleman_1940 Newcomers
      @fredo6 I got an error when i use the JointPushPull "J" tool
      I got the libfredo6-v14.6a and the jointpushpull-v4.8a
      I Just wanted to make thicker a simple rectangle, i know i can use the other tools, but why do this error keeps appearing me in the J especific tool
      What can i do?
      Rich O BrienR B 2 Replies Last reply
        Rich O Brien Moderator @aleman_1940
        @aleman_1940 What version of JJP are you using?
        Can you share the skp that fails?
        A 1 Reply Last reply
        • A
          aleman_1940 Newcomers @Rich O Brien
          @Rich-O-Brien i got the jointpushpull_v4.8a
          The error occurs in every file I work on, since I updated the libfredo and the jpp
          Even when creating new files the error occurs
          Dave RD 1 Reply Last reply
            Dave R @aleman_1940
            @aleman_1940 whyat version of SketchUp are you using?
            • B
              Bifterx @aleman_1940
              @aleman_1940 did you manage to resolve this? I have the exact same issue.
                Rich O Brien Moderator @Bifterx
                @Bifterx @aleman_1940
                Can you both run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu and paste the result here?
                • fredo6F
                  fredo6
                  This problem is related to the model and topology of faces and edges.
                  So, it helps to have the faulty model to reproduce the error and hopefully investigate a fix.
