    70 ton Freight Truck/Bogie
    9 Posts 4 Posters 634 Views 4 Watching
    • Gus RG
      Gus R
      Based on a 70 ton truck in reconditioning manual from Strato Inc, Piscataway, NJ. 68 inch wheelbase and 33 inch diameter wheels. Needs brake system. Have some UP boxcar plans lined up.
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
      Rich O BrienR 1 Reply Last reply Reply Quote 2
        Rich O Brien Moderator @Gus R
        @Gus-R I commend your attention to detail.
        Itโ€™s interesting to see the engineering that went into this tech.
        Are these D5 clay renders?
        • Gus RG
          Gus R @Rich O Brien
          @Rich-O-Brien Thanks rich. It started when I was a kid. The detailing that is. There's a sort of brutalism to heavy freight components. There's also a lot of engineering and physics involved although not in drawing this up. Including a lot of metal levers and chains and early computers for the operating system, remote locomotives, radios, etc.
          • Bryan KB
            Top notch work.
            Gus RG 1 Reply Last reply Reply Quote 2
            • Gus RG
              Gus R @Bryan K
              @Bryan-K Thanks Bryan.
              Exciting new update. These are the mechanical bones of the braking system. Of course I had to be off by 10 degrees with the fulcrum bracket. Supposed to be 40 degrees and not 50 degrees but since the number "4" is right next to "5" I entered "50" instead of "40." This is all over detailed for a boxcar model anyway but I'll change it next.
              Rich O BrienR Mike AmosM 2 Replies Last reply Reply Quote 1
                @Gus-R I would've guessed a much beefier braking system. Surprised to see it's rather rudimentary.
                Great modelling though. Good luck texturing that bad boy!
                  Mike Amos @Gus R
                  @Gus-R Very fine modeling. Going by the "If it looks right" mantra for topics I do not know, that looks perfect.
                  • Gus RG
                    Gus R @Mike Amos
                    @Mike-Amos Put together a quick scene and rendered with some rusty metal I slapped together using Quixel.Mixer.
                    • Bryan KB
                      Top notch!
