    Error with Joint Push Pull
    Scheduled Pinned Locked Moved Solved Plugins
    extensionsbug
    3 Posts 2 Posters 1.5k Views 2 Watching
    • I
      i5963c Extension Creator
      Re: [Plugin][$] JointPushPull Interactive - v4.8a - 30 Mar 24
      I have the latest version of this plugin installed. I also have the required versions of LibFredo6 installed. I'm using Sketchup Make 2017.
      On regular times, the plugin crashes. An example of the crash report is shown below:
      ***Date: 20-May-24 13:15:14 - SU2017.2
      An error occurred in Joint Push Pull
      Error in Analysis of model
      wrong number arguments: 4 or 6 required
      body_lib6g6.rbe: 3139 -- linear_combination
      body_lib6g6.rbe: 3139 -- vector_exact_average
      jointpushpullalgo.rbe: 1369 -- joint_compute_direction
      jointpushpullalgo.rbe: 1315 -- block in block_prepare_vertices_J
      jointpushpullalgo.rbe: 1315 -- each
      jointpushpullalgo.rbe: 1315 -- block_prepare_vertices_J
      jointpushpullalgo.rbe: 1200 -- block in block_prepare_vertices_all
      jointpushpullalgo.rbe: 1200 -- each
      jointpushpullalgo.rbe: 1200 -- block_prepare_vertices_all
      jointpushpullalgo.rbe: 524 -- algo_prepare_calculation_exec
      jointpushpullalgo.rbe: 504 -- algo_prepare_calculation
      jointpushpulltool.rbe: 866 -- dragging_start
      jointpushpulltool.rbe: 1574 -- onLButtonDown***
      As I mentioned, this doesn't occur all the time. However, one process to trigger the error is as follows;
      • Start Sketchup with a new file.
      • Draw a circle in the origin
      • Convert this circle into a cylinder with the standard Sketchup Push/Pull tool.
      • Convert the cylinder into a group
      • Activate the Joint-Push-Pull methods and try to increase the volume of the cylinder.....
      • The error window pops-up...
      From time to time, after doing some other actions, the joint push pull starts working again (even with the same cylinder!)
      PS1: I also tried to downgrade to an earlier plugin version that I still had available on my system (4.6a). The same issue happens with that version.
      PS2: The error happens on my 2 PC's where Sketchup is installed (Windows 10 and Windows 11).
      Thanks to verify what' going on. Hopefully a fix can be provided.
      In case more information would be required, please don't hesitate to ask.
      fredo6F 1 Reply Last reply
      • fredo6F
        fredo6 @i5963c
        @i5963c
        Thanks for signaling the problem, which is due to a side effect of a fix for FredoCorner introduced by LiFredo6 v14.4c.
        I fixed it in LibFredo6 v14.4d, just published.
        I 1 Reply Last reply
        • I
          i5963c Extension Creator @fredo6
          @fredo6
          Thanks a lot for the fast reply and solution.
          Just installed the update and tested it. It works!
          Up and running again.
          • Rich O BrienR Rich O Brien marked this topic as a question on
