    Fredo Corner Not Showing in Extensions Menu
    Scheduled Pinned Locked Moved Solved Extensions & Applications Discussions
    12 Posts 5 Posters 1.1k Views 5 Watching
    • M
      mstewart
      I purchased Fredo Corner extension & License. Validated license, Downloaded everything, and no matter what I do, the Fredo Corner extension is not showing up in my Sketchup Extensions Menu. Please help! I paid for everything and I'm getting NOTHING for it! Many thanks to all who offer help! Currently using Sketchup 2023.
      • M
        mstewart @Rich O Brien
        @Rich-O-Brien
        Here you go Rich. MANY thanks to you!
        Fredo6 Plugins Information on 2024-05-17 19:03:43 -0400
        • Platform: x64-mswin64_140 - Ruby: 2.7.7
        • Sketchup: 23.1.340
        • LibFredo6: v13.9a
        • LibFredo6 Binary loaded
        • Sketchucation ExtensionStore: 4.4.1
        • SCFLicense: v6.4a - 74
        • Fredo6 Plugins
        • SCFLicense directory present
          Signature File: 2024-05-17 15:21:00 -0400
          FredoCorner: 2024-05-17 15:27:14 -0400
          Fredo Corner resides under Tools > Fredo Collection > Fredo Corner
          Can you do the following:
          Run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
          M 1 Reply Last reply
          • M
            @Rich-O-Brien
            • LibFredo6: v13.9a
            • Fredo6 Plugins
              Rich O Brien Moderator @mstewart
              @mstewart Looks like you have yet to install FredoCorner
              SketchUp Plugins | PluginStore | SketchUcation
              SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
              (sketchucation.com)
              Or you can install it directly in SketchUp using our own ExtensionStore
              • M
                mstewart
                Rich,
                MANY, MANY thanks to you! I uninstalled both LibFredo6 and FredoCorner, then reinstalled both of them through the plugin store. Now everything is loaded and presumably functional. This is a great community. High fives to you Rich!
                • Rich O BrienR Rich O Brien marked this topic as a question on
                  @mstewart No problems. It can be confusing to get it all setup correctly if your new to it.
                  • T
                    tassochia
                    @Rich-O-Brien
                    Hello,
                    I'm new to this plugin ... i have problems on using fredo corner ... it doesn't work.. it doesn't appear the pannel (not the icons) ... please help me!
                    Chiara
                    Fredo6 Plugins Information on 2025-02-27 11:02:25 +0100
                    • Platform: x64-mswin64_140 - Ruby: 3.2.2
                    • Sketchup: 24.0.553
                    • LibFredo6: v15.0a
                    • Fredo6 Plugins
                      FredoCorner v2.7a - licensed FULL
                      Signature File: 2025-02-27 10:18:33 +0100
                      FredoCorner: 2025-02-27 10:49:49 +0100
                      Do you have any ruby console messages?
                      Send an email to support@sketchucation.com and we can try help
                      • fredo6F
                        fredo6
                        Do you see the menus in Tools > Fredo6 Collection... > FredoCorner
                          @fredo6 this person has contacted us through support
                          I'll paste the console errors here for you to see.
                          Error: #<Errno::EACCES: Permission denied @ rb_sysopen - C:/Users/tasso/AppData/Local/LIBFREDO6_DATA_Dir/LibFredo6_all_defaults.dat>
                          c:/users/tasso/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:167:in `initialize'
                          c:/users/tasso/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:167:in `open'
                          c:/users/tasso/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:167:in `write_to_file'
                          c:/users/tasso/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:150:in `store'
                          c:/users/tasso/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1474:in `usage_use'
                          c:/users/tasso/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1462:in `command_invoke'
                          c:/users/tasso/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1443:in `block (2 levels) in build_config_commands'
                          c:/users/tasso/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1489:in `block in add_command'
                          I've asked for them to repair SketchUp install using Run as Admin
                          But if you have further info that'd be great as I have 2 more similar issues in support inbox around Curviloft
                          • T
                            tassochia
                            I did it!!!!!
                            1. Delete the Problematic File (Force Reset Fredo6 Defaults) .. i just change de extension.....
                              Close SketchUp.
                              Delete LibFredo6_all_defaults.dat (SketchUp will recreate it).
                              Restart SketchUp.
                            • TIGT
                              The LibFredo6_all_defaults.dat can have incorrect permissions if SketchUp was installed incorrectly [i.e. not using 'Run as administrator']
                              Although running it again 'as administrator' and choosing 'Repair' should fix most permission issues, some remain - especially with extensions saved files/folders.
                              Deleting the the LibFredo6_all_defaults.dat while SketchUp is closed should work as SketchUp will recreate it with the correct permissions when it next runs.
