    Fredo Corner Not Showing in Extensions Menu
    Scheduled Pinned Locked Moved Solved Extensions & Applications Discussions
    12 Posts 5 Posters 934 Views 5 Watching
      mstewart @Rich O Brien
      @Rich-O-Brien
      Here you go Rich. MANY thanks to you!
      Fredo6 Plugins Information on 2024-05-17 19:03:43 -0400
      • Platform: x64-mswin64_140 - Ruby: 2.7.7
      • Sketchup: 23.1.340
      • LibFredo6: v13.9a
      • LibFredo6 Binary loaded
      • Sketchucation ExtensionStore: 4.4.1
      • SCFLicense: v6.4a - 74
      • Fredo6 Plugins
        Signature File: 2024-05-17 15:21:00 -0400
        FredoCorner: 2024-05-17 15:27:14 -0400
        Rich O Brien Moderator @mstewart
        @mstewart Looks like you have yet to install FredoCorner
        SketchUp Plugins | PluginStore | SketchUcation
        SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
        (sketchucation.com)
        Or you can install it directly in SketchUp using our own ExtensionStore
          mstewart
          Rich,
          MANY, MANY thanks to you! I uninstalled both LibFredo6 and FredoCorner, then reinstalled both of them through the plugin store. Now everything is loaded and presumably functional. This is a great community. High fives to you Rich!
          • Rich O BrienR Rich O Brien marked this topic as a question on
            @mstewart No problems. It can be confusing to get it all setup correctly if your new to it.
            • T
              tassochia
              @Rich-O-Brien
              Hello,
              I'm new to this plugin ... i have problems on using fredo corner ... it doesn't work.. it doesn't appear the pannel (not the icons) ... please help me!
              Chiara
              Fredo6 Plugins Information on 2025-02-27 11:02:25 +0100
              • Sketchup: 24.0.553
              • LibFredo6: v15.0a
              • Fredo6 Plugins
                FredoCorner v2.7a - licensed FULL
                Signature File: 2025-02-27 10:18:33 +0100
                FredoCorner: 2025-02-27 10:49:49 +0100
                Do you have any ruby console messages?
                Send an email to support@sketchucation.com and we can try help
                • fredo6F
                  Do you see the menus in Tools > Fredo6 Collection... > FredoCorner
                    @fredo6 this person has contacted us through support
                    I'll paste the console errors here for you to see.
                    Error: #<Errno::EACCES: Permission denied @ rb_sysopen - C:/Users/tasso/AppData/Local/LIBFREDO6_DATA_Dir/LibFredo6_all_defaults.dat>
                    c:/users/tasso/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:167:in `initialize'
                    c:/users/tasso/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:167:in `open'
                    c:/users/tasso/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:167:in `write_to_file'
                    c:/users/tasso/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:150:in `store'
                    c:/users/tasso/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1474:in `usage_use'
                    c:/users/tasso/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1462:in `command_invoke'
                    c:/users/tasso/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1443:in `block (2 levels) in build_config_commands'
                    c:/users/tasso/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1489:in `block in add_command'
                    I've asked for them to repair SketchUp install using Run as Admin
                    But if you have further info that'd be great as I have 2 more similar issues in support inbox around Curviloft
                    • T
                      tassochia
                      I did it!!!!!
                      1. Delete the Problematic File (Force Reset Fredo6 Defaults) .. i just change de extension.....
                        Close SketchUp.
                        Delete LibFredo6_all_defaults.dat (SketchUp will recreate it).
                        Restart SketchUp.
                        The LibFredo6_all_defaults.dat can have incorrect permissions if SketchUp was installed incorrectly [i.e. not using 'Run as administrator']
                        Although running it again 'as administrator' and choosing 'Repair' should fix most permission issues, some remain - especially with extensions saved files/folders.
                        Deleting the the LibFredo6_all_defaults.dat while SketchUp is closed should work as SketchUp will recreate it with the correct permissions when it next runs.
