    RayScaper
    rayscaper
    86 Posts 9 Posters 15.7k Views 8 Watching
    • majidM
      majid
      Thanks Thomas.
      I shared the model so that everyone could play with it. The brick texture is of low quality, so please replace it.
      https://3dwarehouse.sketchup.com/model/ef4e0de4-4028-4425-95f3-3ae49758665e/Interior-scene-adjusted-for-Rayscaper
      • pixelcruncherP
        pixelcruncher Extension Creator @majid
        @majid Thanks for sharing the model! Super useful for others wanting to try Rayscaper.
        majidM 1 Reply Last reply
        • majidM
          majid @pixelcruncher
          @pixelcruncher My pleasure to have my hands on such a charming piece of software. Considering my laptop is rather old, not supporting recent graphic cards and all the computation is done by the processor.
          Here are more tries to discover the "coating" layer .
          Reply Quote 3
          • pixelcruncherP
            Very nice renders, they make for excellent Rayscaper marketing materials πŸ™‚
            Mike AmosM 1 Reply Last reply
            Reply Quote 2
              Mike Amos @pixelcruncher
              @pixelcruncher
              I can only concur with that sentiment.
              Reply Quote 3
              • majidM
                majid
                Thanks for the compliment. I am still experimenting with the coating layer and maybe am not using the right template but the result is amazing.
                • majidM
                  majid @majid
                  I modeled the building, textured and rendered it to try the exterior scene. Texturing needs more attention and I will rectify it later. By the way, I liked the result.
                  pixelcruncherP ntxdaveN 2 Replies Last reply
                  • pixelcruncherP
                    @majid I'm Looking forward to seeing this finished! This is going to be a beautiful architectural render.
                    Cheers,
                    Thomas
                    • ntxdaveN
                      ntxdave @majid
                      @majid how do you get texture like the one on the walls?
                      Press F1...thank me later
                      • majidM
                        majid @ntxdave
                        @ntxdave I made the texture and applied it to the walls, some part is not textured properly and I will fix it.
                        ntxdaveN 1 Reply Last reply
                        • ntxdaveN
                          ntxdave @majid
                          @majid said in RayScaper:
                          How do you do that? I would like to learn this. πŸ‘
                          • majidM
                            majid @ntxdave
                            @ntxdave Started from a concrete texture and modified it using an image editor (Photopea)
                            • majidM
                              majid
                              Here are some more renders of the same model.
                              Reply Quote 2
                                Mike Amos @majid
                                @majid
                                I prefer these tbh, the previous version had what looked like overscale texturing.
                                Very sharp now mate.
                                • pixelcruncherP
                                  Great work @majid - Love the house and love the renders. Also a great showcase for Rayscaper exterior renders.
                                  majidM pixelcruncherP 2 Replies Last reply
                                  • majidM
                                    @pixelcruncher Thanks.
                                    It could be way better. It was a test.
                                    My machine does not handle high-poly trees. Otherwise the result could be more real.
                                    • majidM
                                      majid @Mike Amos
                                      @Mike-Amos you are right dear friend.
                                      • pixelcruncherP
                                        pixelcruncher Extension Creator @pixelcruncher
                                        @majid I think even the use of the textured "cards" looks very nice. It's a good trick for faster render times and protecting SketchUp from becoming very slow. It's also a good test to prove that you don't need the latest high-end hardware to get good visualizations with Rayscaper.
                                        • majidM
                                          @pixelcruncher
                                          I used a combination of a 3D model and a "face me "component for grass.
                                          I made a very simple component ( a square and a vertical line) then included my grass models inside it. The simple one is on one "tag" or layer and the detailed and face me model are on another "tag" or layer. Then made the "heavy" tag/layer invisible to move between scenes,
                                          This way I can handle grass easily.
                                          • majidM
                                            majid @majid
                                            I had the chance to prepare a video on utilizing Rayscaper in product (car) rendering.
                                            Here is the link to it, Happy Rayscapering!:
                                            https://youtu.be/rhct92eJDtc
                                            • 4 / 5
