    RayScaper
    rayscaper
    86 Posts 9 Posters 14.8k Views 8 Watching
    • P
      pixelcruncher Extension Creator @majid
      @majid Very nice renders, thanks for sharing.
      And the missing fake emission option is a bug! Thanks for reporting, I will make sure it's back in the next release.
      • majidM
        majid
        Thanks Thomas.
        I shared the model so that everyone could play with it. The brick texture is of low quality, so please replace it.
        https://3dwarehouse.sketchup.com/model/ef4e0de4-4028-4425-95f3-3ae49758665e/Interior-scene-adjusted-for-Rayscaper
        P 1 Reply Last reply
        • P
          @majid Thanks for sharing the model! Super useful for others wanting to try Rayscaper.
          majidM 1 Reply Last reply
          • majidM
            majid @pixelcruncher
            @pixelcruncher My pleasure to have my hands on such a charming piece of software. Considering my laptop is rather old, not supporting recent graphic cards and all the computation is done by the processor.
            Here are more tries to discover the "coating" layer .
            Reply Quote 3
            • P
              Very nice renders, they make for excellent Rayscaper marketing materials πŸ™‚
              Mike AmosM 1 Reply Last reply
              Reply Quote 2
                Mike Amos @pixelcruncher
                @pixelcruncher
                I can only concur with that sentiment.
                Reply Quote 3
                • majidM
                  majid
                  Thanks for the compliment. I am still experimenting with the coating layer and maybe am not using the right template but the result is amazing.
                  • majidM
                    majid @majid
                    I modeled the building, textured and rendered it to try the exterior scene. Texturing needs more attention and I will rectify it later. By the way, I liked the result.
                    P ntxdaveN 2 Replies Last reply
                    • P
                      @majid I'm Looking forward to seeing this finished! This is going to be a beautiful architectural render.
                      Cheers,
                      Thomas
                      • ntxdaveN
                        ntxdave @majid
                        @majid how do you get texture like the one on the walls?
                        Press F1...thank me later
                        • majidM
                          majid @ntxdave
                          @ntxdave I made the texture and applied it to the walls, some part is not textured properly and I will fix it.
                          ntxdaveN 1 Reply Last reply
                          • ntxdaveN
                            ntxdave @majid
                            @majid said in RayScaper:
                            How do you do that? I would like to learn this. πŸ‘
                            • majidM
                              majid @ntxdave
                              @ntxdave Started from a concrete texture and modified it using an image editor (Photopea)
                              • majidM
                                majid
                                Here are some more renders of the same model.
                                Reply Quote 2
                                  Mike Amos @majid
                                  @majid
                                  I prefer these tbh, the previous version had what looked like overscale texturing.
                                  Very sharp now mate.
                                  • P
                                    Great work @majid - Love the house and love the renders. Also a great showcase for Rayscaper exterior renders.
                                    majidM P 2 Replies Last reply
                                    • majidM
                                      @pixelcruncher Thanks.
                                      It could be way better. It was a test.
                                      My machine does not handle high-poly trees. Otherwise the result could be more real.
                                      • majidM
                                        majid @Mike Amos
                                        @Mike-Amos you are right dear friend.
                                        • P
                                          pixelcruncher Extension Creator @pixelcruncher
                                          @majid I think even the use of the textured "cards" looks very nice. It's a good trick for faster render times and protecting SketchUp from becoming very slow. It's also a good test to prove that you don't need the latest high-end hardware to get good visualizations with Rayscaper.
                                          • majidM
                                            @pixelcruncher
                                            I used a combination of a 3D model and a "face me "component for grass.
                                            I made a very simple component ( a square and a vertical line) then included my grass models inside it. The simple one is on one "tag" or layer and the detailed and face me model are on another "tag" or layer. Then made the "heavy" tag/layer invisible to move between scenes,
                                            This way I can handle grass easily.
                                            • 4 / 5
