    Draw an octagon an a Swiss keyboard
    9 Posts 6 Posters 739 Views 6 Watching
      Alohaa
      Hello,
      how can I draw an octagon on a Swiss keyboard where the + is only accessible via Option & Shift?
      When I draw a hexagon and then click on Option & Shift & + nothing happens
      Kind regards
      Alohaa
      • Rich O BrienR Online
        Pick the Circle tool
        Press 8 and hit Enter to set the segment count of the circle
        Draw your 8 segment circle
        https://i.imgur.com/DQwR4hY.gif
        No need to perform any finger yoga
          Or pick the Polygon tool, type 8, press Enter and draw the octagon.
          Click on the picture
            I never knew it existed 😳
            I've not had native toolbars enabled in years....
              Alohaa
              Thank you!
              The method with the polygone tool works, that with the circle doesn't. I may change the number of segments from 24 to 8, but nevertheless the circle is drawn with 24 segments.
              I have always the instruction in the bar beneath to press Option and + to change the number of segments.
              • BoxB Offline
                It does work with both circle and polygon the same way, make sure you are doing as instructed.
                Select the tool and before doing anything type 8 and hit enter to confirm, then draw your circle or polygon and it will have 8 segments/sides.
                Note: this method will set the default for that tool to 8, so each circle or polygon will have 8 segments until you change it or start a new instance of Sketchup.
                The other option if you want to retain the default 24 or 6 and just draw one C/P with a different number, Select the tool and draw your shape, then type 8s and hit enter to confirm and the shape will change to 8 segments.
                  rv1974
                  type s for segments number: 8s
                  might be your case - many shortcuts are broken in the latest su build
                  • Jean LemireJ Offline
                    Jean Lemire
                    p.s. never saw the need in this tool - circle is universal
                    If you push or pull a polygon, you get a polygonal prism.
                    If you push or pull a circle, the longitudinal edges are smoothed so you get a cylinder.
                    Of course, you can soften the edges of a polygonal prism to get a cylinder or unsmooth the edges of a cylinder to get a polygonal prism but this is extra work.
                      rv1974
                      Haha with this approach Trimble could make a smooth/unsmooth variant for each tool
