    How to determine in which font a text was written
    10 Posts 4 Posters 1.3k Views 4 Watching
      Alohaa
      Hello,
      I have a text that I need to correct, but I no longer know which font it was written in. Is this information available in SU? I don't find it anywhere.
      I have tried all the fonts available in SU, but it is none of those and I don't understand how I could have written it in a non present font!
      Kind regards
      Alohaa
        SketchUp Pro lists all of the ttf fonts installed on your computer.
        So you should be able to find it... ๐Ÿ˜ฎ
        • Rich O BrienR Online
          3D or 2D text?
            Alohaa
            3D Text
              Since 3D text is actual geometry it is not editable without an extension.
              But if you screenshot your text and upload it to https://www.myfonts.com/pages/whatthefont it might identify what the font is.
                Alohaa
                Ok, thanks.
                Which extension enables editing?
                  https://sketchucation.com/pluginstore?pln=tt_texteditor
                    Alohaa
                    Thank you!
                      Note that the 3D text needs to have been created with that extension in order to be editable. If it was created with the native 3D Text tool, the extension won't work on it.
                        Alohaa
                        Thank you for the offer!
                        I have since realised that I did not create the text in question in SU, but in Estlcam, the program in which I load the dxf and define the milling paths, and which is just as inflexible as far as this question is concerned, and have been able to identify the font in the long list: Monotype.
                        But, since I sometimes create it directly in SU, the question still arises. I will install this extension. If I don't get along, I will post the skp.
                        With kind regards
                        Alohaa
