    2023 Tray Issue
    8 Posts 2 Posters 414 Views 2 Watching
    • boofredlayB Offline
      boofredlay
      I installed 2023 as administrator yesterday then installed a few plugins. After setting them up I am getting this with the trays. And trying to turn on and off layers, unresponsive.
      I ran as administrator and just did a repair and still...
      Any ideas?
        Is this happening with no extensions running?
        If you dock the trays is it still persistent?
        What version of Windows is that? v10?
        I have 2023 trays undocked too and I'm running Windows 11
        https://i.imgur.com/tDvsyKA.png
        Here's my settings and I don't get any black tray panels
          boofredlay
          Windows 10.
          Same settings.
          No plugins running that I am aware of. Does this on startup.
          Odd thing, I docked each tray then un-docked them and they are working fine now.
          Thanks Rich.
            boofredlay
            Hmmm, seems I need to do that each time I load SU. Not ideal.
              So every undocked tray needs to be docked/undocked to force refresh?
              What if you assign a shortcut key to show/hide tray then after startup you launch tray via shortcut key? So never start SketchUp with any trays loading.
                boofredlay
                Yep.
                I just got off the phone with Dave R. and apparently it is a known issue being worked on so I will just deal with it until there is a fix.
                  boofredlay
                  That works but only for the default tray. I have 4 total.
                    boofredlay
                    Thanks guys for the assist.
