    How to export img that every entity is shown by exact color
    8 Posts 4 Posters 221 Views 4 Watching
    • W Offline
      wikii
      Hi all , I want to find a way to export seg img to Stable Diffusion.
      Can Sketchup export image , that every thing is shown with the exact color defined by it's tag,no shadow,no darkness,no high light,no fade.... just some flat color.
      Like this:
      IF the tag's color is rgb(120,120,120),in the eported img ,eveyr object use this tag is a field color of rgb(120,120,120).
      Thank a lot.
        Style > Color by Tag [Layer] checked.
        Shadows > Light=0, Dark=100
        • W Offline
          wikii
          Thank you for reply.
          I do it as your prompt, color RGB(120,120,120) export to img, changes to RGB(144,144,144).
          Dark = 80 ,color RGB(120,120,120) export to img, changes to RGB(119,119,119).
          Dark = 81 ,color RGB(120,120,120) export to img, changes to RGB(121,121,121).
          can Sketchup export img with exact RGB(120,120,120)?
            That's as close as you can get...
            • W Offline
              wikii
              thank you,but, it is not what i want.
                Try adjusting the Dark slider down a little. For me the Light slider at 1 and the Dark slider at 80 works.
                With your graphics card it might be different.
                • W Offline
                  wikii
                  [attachment=1:20q54dze]<!-- ia1 -->Screenshot - 4_19_2023 , 6_36_38 AM.png<!-- ia1 -->[/attachment:20q54dze]
                  [attachment=0:20q54dze]<!-- ia0 -->Screenshot - 4_19_2023 , 6_36_13 AM.png<!-- ia0 -->[/attachment:20q54dze]
                  Thank you!
                  • HornOxxH Offline
                    HornOxx
                    Hi All, maybe not exactly what is asked here but because colour accuracy is the topic here and this question is professionally very important for me as well.
                    As a rule, and only where colour accuracy is priority #1 which happens quite often with me: In these cases I never export a pixel image out of SkUp but always a PDF (with or without lines). I import this PDF into Adobe Illustrator (or any similar tool), automatically select the relevant fill colours and then, within Adobe Illustrator, convert them to the exactly calibrated colours of our own specific Adobe colour profile. If necessary, I also combine this (still rather dull) PDFs within Adobe Illustrator with an ambient occlusion or shadow rendering of my model which I overlay multiplying there.
                    πŸ˜‰ I hope this method helps...
                    never trust a skinny cook
