    Trying to draw an elliptical cone
    27 Posts 7 Posters 494 Views 7 Watching
      But I thought I'd try an elliptical horn rather than round. I had no idea I was opening a new can of worms
      The worm is the native only approach. Since SU is primarily a conceptual design tool and you require some level of accuracy its supported via extensibility.
      The core can't do it but it can be done.
      • panixiaP Offline
        panixia
        @frascati said:
        "Rich showed you a native way to do it."
        "Smoove has a falloff...."
        I need to go back and change my "intermediate" level of understanding to "beginner"
        "Smoove" is a member here? And a "falloff" is a what? Do the four images he posted suffice as a "tutorial"?
        Not sure why you are so rude, nobody is in owe of doing turorials for you.
        By the way what Rich said is more than enough, those are the only (pretty self explainatory) tools to attempt a similar shape in vanilla Sketchup.
        As already said, is pointless to try to model this kind of shapes using only native tools.
        Here's my 15 minutes draft using QFT/VT2/SubD.
        SubD_Speaker.skp
        • frascatiF Offline
          frascati
          It was actually a very mild RE-action to being confidently assured that I'd been "shown" the way to do it already.
          You considered my response rude? Really? You need to get out of the house more. I absolutely take offense to being called rude when my conduct does not merit it.
          You have offered the initial rudeness here. Please refrain from comment in any further topics I submit.
          • frascatiF Offline
            frascati
            ok
            • HornOxxH Offline
              HornOxx
              Besides all the other good solutions above, here is another very quick one:
              Not native but with the plugin Cruviloft you can also achieve this desired geometry with ease.
              With the same tool and with the same simple principle you can get even further than just to the speakers.
              In the middle is the circle - around it is a small number of elypses which you move (up) to your desired positions. Then you let the plugin work which generates the desired shape with the preferred segmentations and smoothing by clicking on the circle and elypses plygons in the correct order - Done!
              (Above a certain level of complexity it is advisable to consider plugins rather than torturing yourself with the native options - especially if you are dealing with organic shapes)
              never trust a skinny cook
              • frascatiF Offline
                frascati
                Thank you HornOxx. That looks promising. I'll give it a go.
                • frascatiF Offline
                  frascati
                  This AI is kinda fun
                  • 2 / 2
