    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    How to stop paint changes from being applied globally?
    4 Posts 4 Posters 66 Views 4 Watching
    • frascatiF Offline
      frascati
      I have painted multple objects with the same color texture and opacity. One of those objects i wish to adjust the opacity level different from the rest. How do i change one without affecting all the others?
      • TIGT Online
        Create a new material using the same RGB etc then change its opacity as desired.
        Name it something obvious so you can find it - e.g. mylovelymaterial >>> mylovelymaterial_1
        Repaint the objects with the new material as you need...
          I just had a Father Ted flashback...
            FredoGhost
