    Fredo extension
    8 Posts 7 Posters 353 Views 7 Watching
    • F
      Fcerquinho
      I did understand that now we have to pay for Fredo Round Corner. I tried to buy Fredo but the "circle" goes round and round and round, and nothing happens.
      Any help, please?
      Fernanda
        Try a different browser or disable any javascript blocking extensions that would stop PayPal working.
        • dapillsburyjrD
          dapillsburyjr
          FredoCorner is not responding. Nothing happens when you select any button. I've been a member for years, and I've made a donation. Is there anything else I need to do to get it working?
          TIGT fredo6F 2 Replies Last reply
          • TIGT
            TIG Moderator @dapillsburyjr
            @dapillsburyjr
            Many of Fredo's extensions need you to buy and validate a license for each of them - they are not costly and combo-bundles are available...
            • fredo6F
              fredo6 @dapillsburyjr
              @dapillsburyjr
              Can you open the Ruby console before you launch a plugin. There may be errors. If so, just copy/paste it here.
              Also could you copy paste the out put when you invoke the menu Window >LibFredo6 Settings.... > Fredo6 Plugins Information for Sketchucation Support.
              This will tell on which paltform and with which version you run my plugins.
              • B
                baro
                Having a problem with the plugin i purchased that requires Libfredo6.
                Extension Errors Report
                SketchUp: 26.1.256
                OS: Windows 11
                Ruby: 3.2.2
                Extension: Fredo6 LibFredo6 (1.0)
                Error: NameError (uninitialized constant E6B)
                C:/Users/User/AppData/Local/Temp/Fredo6__loader_top_1795173323.rb:1:in `<top (required)>'
                C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/extensions.rb:197:in `require'
                C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/extensions.rb:197:in `load'
                C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:153:in `register_extension'
                C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:153:in `process'
                C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:164:in `<module:LibFredo6_Loader>'
                C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/Fredo6_!LibFredo6.rb:31:in `<top (required)>'
                  Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                  • KrassK
                    Krass
                    Fredo6’s bundle is brilliant and inexpensive. However, for chamfers and fillets—or "bevels"—this plugin produces fewer errors; it automatically adjusts the offset whenever it cannot cleanly process an edge.
                    https://github.com/TomaszDzieduszynski/simple-corners?utm_source=chatgpt.com
                    It's free
                    Krass
