    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Cast Iron Spiral Stair
    13 Posts 10 Posters 1.3k Views 10 Watching
      Modeled to go with a large steam engine.
      https://live.staticflickr.com/65535/52468627894_28703383e7_h.jpg
      https://live.staticflickr.com/65535/52468833751_498e664e5b_h.jpg
      • boofredlayB Offline
        boofredlay
        Well done Dave. This is amazing ❗
        • ntxdaveN Offline
          ntxdave
          Really nice sir! πŸ‘ πŸ‘
          You must have/use a ton of plugins to create something like this. πŸ˜„
          Press F1...thank me later
            Thank you gentlemen.
            As for plugins, I used Eneroth Upright Extruder for the rail on top of the spindles and Eneroth Auto Weld on the parts so the Sketchy edges would look nice. Oh, and FredoSpline for the vase shape on the top center post section. Is that a ton?
            • ntxdaveN Offline
              ntxdave
              Far less than I would have expected. πŸ‘
              • HornOxxH Offline
                HornOxx
                ...a masterpiece! großartig πŸ‘
                never trust a skinny cook
                • Bryan KB Offline
                  Wa... WOW! πŸ‘ πŸ‘ πŸ‘
                    Really beutifull work πŸ‘ πŸ‘
                      ^ What they said, quite brilliant.
                      • alvisA Offline
                        alvis
                        wow how beautiful metal can be!!! πŸ‘ πŸ‘ πŸ‘
                        • marked001M Offline
                          marked001
                          wow.. awesome!
                          http://www.revision21vis.com
                          instagram: revi21on
                            Thanks all. I discovered I missed adding a couple of finial/nuts on the bottom of the treads. Easily added due to the use of nested components. πŸ˜‰
                            https://live.staticflickr.com/65535/52483217292_5ca663bd24_b.jpg
                              db11
                              Gorgeous work Dave.
