    Creating a face
    3 Posts 2 Posters 749 Views 2 Watching
    • 6
      68Trackman
      Hi all...
      Am hoping this is fairly pedestrian and some body can send me to a pre existing answer..
      Not everything in life is orthogonal...
      I have made several attempts at creating a face that does not align with the orthogonal axes in SU, but mirrors the terrain imported via a TIN file from the surveyor...
      I thought I had a work around with the freehand tool, but in a 3D environment, while you may be following some guide lines, SU is merrily drawing a face in it's own plane...
      What to do....?
      thanks,
      Stuart.
        You cannot draw on a surface in SketchUp using native tools. Fredo's ToolsonSurface extension has that ability.
        https://sketchucation.com/pluginstore?pln=ToolsOnSurface
        Not sure how long the trial is but definitely enough to see if it is what you need.
        Make sure to install our own Sketchucation Tools first....
        Sketchucation Tools | SketchUcation
        (sketchucation.com)
        the LibFredo...
        SketchUp Plugins | PluginStore | SketchUcation
        SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
        (sketchucation.com)
        then...
        (sketchucation.com)
        • 6
          68Trackman
          Got all that, thanks...
          I may be suffering from my version (SU8) though...
          Can install the sketchucation plugin, but nothing appears in the program.
          Likewise with Toolsonsurface...
          I do already have LibFredo installed and Fredo tools, among other things.
          I found version 1.8 of the Toolsonsurface, as a zip file. Followed the premise of unzipping and copying to the plugins folder, but again, never appears in the program...
          I have a sense that it all ends here...
          Thanks for chiming in all the same...
