    Can't close/differenciate faces
    5 Posts 3 Posters 1.2k Views 3 Watching
    • V Offline
      valleybeach
      There is probably a simple answer to this, but why can I sometimes not select these faces independently? In this example the face has been closed but is still connected to face outside the bounding edges? What am I missing? Thanks in advance! Seth
      Screen Recording 2022-10-06 at 10.40.31 AM.zip
        Hard to say from the video. The heavier edges show that it is not merged.
        If you Select All right click and choose...
        https://i.imgur.com/we5FCAp.png
        ...does it join the geometry
        Fredo Tools > Edge Inspector has an option to fix such issues.
        • V Offline
          valleybeach
          Thanks for the response, Rich...and sorry for the slow reply. I didn't get a notification that there had been a response posted. So I tried select all and tried to intersect faces with selection but it didn't seem to change anything, including the heavier edges.
          • V Offline
            valleybeach
            Any other ideas on what I may be doing wrong or missing here? This is pretty frustrating because this is a new issues that has popped up so I assume I am missing something obvious...
              If you shared the file it would help us help you get the issue sorted out.
