    Fancy brickwork generator?
    4 Posts 2 Posters 2.4k Views 2 Watching
    • L
      Hi, I have attached an image of a window within an arch. I would like to know if there are any brickwork editors. I think I saw a post on this forum and from memory it seemed like it covered this issue. Does anybody know of such an app?
        Gus posted this yesterday...
        https://sketchucation.com/forums/viewtopic.php?f=40&t=75189
        You can generate the bond type for both the wall and arch using same brick material.
        For normal, AO etc you need to delight the diffuse then generate maps.
        • L
          Thanks Rich, I am aware of the post by Gus R (Thanks Gus) And had a look at the link. I think that is all new brickwork and I am intersested in some more heritage buildings
            With a bit of work with the ACME tool as a base you could get close.
            https://i.imgur.com/1Dx3B1m.png
            https://i.imgur.com/Nyd55LO.png
            Obviously spend more time than I did but its to give an example
