    Fancy brickwork generator?
    4 Posts 2 Posters 2.2k Views 2 Watching
      Hi, I have attached an image of a window within an arch. I would like to know if there are any brickwork editors. I think I saw a post on this forum and from memory it seemed like it covered this issue. Does anybody know of such an app?
        Gus posted this yesterday...
        https://sketchucation.com/forums/viewtopic.php?f=40&t=75189
        You can generate the bond type for both the wall and arch using same brick material.
        For normal, AO etc you need to delight the diffuse then generate maps.
          Thanks Rich, I am aware of the post by Gus R (Thanks Gus) And had a look at the link. I think that is all new brickwork and I am intersested in some more heritage buildings
            With a bit of work with the ACME tool as a base you could get close.
            https://i.imgur.com/1Dx3B1m.png
            https://i.imgur.com/Nyd55LO.png
            Obviously spend more time than I did but its to give an example
