    Tapering a Curve
    5 Posts 3 Posters 3.6k Views 3 Watching
    • D
      djc87
      Is there an easy way to taper along a curve? In the image attached, The left side is my starting point bottom curve and heights required at both ends. The right is my attempt using the existing bottom curves but I lose an unacceptable amount of accuracy with this attempt. Is there an extension that can do this? Any feedback helps. Thanks
        Fredo6's Curvishear would be one option.
        • D
          djc87
          I just tried Curvishear but getting a "NO curve in the selection". I tried "Grouping" but that didn't solve it. Is there another step to make the selection a curve?
            Curvishear is pretty accurate...
            • D
              djc87
              I think I figured out my "NO curve in the selection" issue. I had to select the line and then convert it to curve using BZ-Convert to -> Classic Bezier curve. This seemed to group it in a way that CurviShear could read.
              Thank you all for the responses
