    Ifc import
    12 Posts 3 Posters 9.0k Views 3 Watching
    • jo-keJ
      jo-ke
      my customer sent me some ifc files.
      I tried to import to sketchup but import failed.
      what can I do?
      Any chance to convert to sketchup?
      http://www.zz7.de
      • L
        1, Go to the file File menu inside Sketchup.
        2, Click Import.
        3, click the drop-down (bottom right) and select all supported types.
        4, Navigate to the IFC file and left-click the file.
        5, Click import at the bottom right-hand side.
        I assume you tried it this way?
          Try viewing the file at...
          Site not found · GitHub Pages
          (ifcjs.github.io)
          If that fails try the free BlenderBIM addon
          https://blenderbim.org/
          ...then export to .dae
          • jo-keJ
            jo-ke
            Yes I did it like you discribed.
            I will try the blender way...
            thank you!
            http://www.zz7.de
            • jo-keJ
              jo-ke
              I intalled the blenderplugin.
              It worked well with the smallest ifc file (582 kb)
              but the most important file is to huge, Blender is crashing (120 MB)
              I can open it in the viewer https://ifcjs.github.io/web-ifc-viewer/example/index
              but I can not convert it into another format.
              There ist a downloadbutton and a dropbox button but they do not work
              what can I do?
              can somebody convert for me?
              http://www.zz7.de
                Can you open the file with this...
                Open IFC Viewer
                Open IFC Viewer is a professional-grade IFC viewer
                Open IFC Viewer (openifcviewer.com)
                Also try this...
                (www.ifcopenshell.org)
                • jo-keJ
                  jo-ke
                  can I convert with it or only open it?
                  opening works fine with the first one but I was not able to convert it.
                  http://www.zz7.de
                    The first is a viewer only. It's to see if the file will actually open.
                    The second allows you to convert. I was interested to see if the file itself would open elsewhere.
                    • jo-keJ
                      jo-ke
                      Open IFC Viewer
                      Also try this...
                      first one: I can open it but the grafic look s wired. Not option to export to collada
                      second one: installation failed but description sounds interessting. Tried to install different versions, all failed.
                      http://www.zz7.de
                        I'm out of options I'm afraid.
                        Ask your client to export to a different format. IFC can be hit or miss because its not just mesh data and that is likely all you need.
                        • jo-keJ
                          jo-ke
                          My client was able to convert to sketchup.
                          thank you
                          http://www.zz7.de
                            Out of curiosity, what did that 120mb .ifc become in size when converted to .skp
