Ifc import
12 Posts 3 Posters 7.1k Views 3 Watching
    jo-ke
    my customer sent me some ifc files.
    I tried to import to sketchup but import failed.
    what can I do?
    Any chance to convert to sketchup?
    http://www.zz7.de
      1, Go to the file File menu inside Sketchup.
      2, Click Import.
      3, click the drop-down (bottom right) and select all supported types.
      4, Navigate to the IFC file and left-click the file.
      5, Click import at the bottom right-hand side.
      I assume you tried it this way?
        Try viewing the file at...
        Site not found · GitHub Pages
        (ifcjs.github.io)
        If that fails try the free BlenderBIM addon
        https://blenderbim.org/
        ...then export to .dae
          jo-ke
          Yes I did it like you discribed.
          I will try the blender way...
          thank you!
          http://www.zz7.de
            jo-ke
            I intalled the blenderplugin.
            It worked well with the smallest ifc file (582 kb)
            but the most important file is to huge, Blender is crashing (120 MB)
            I can open it in the viewer https://ifcjs.github.io/web-ifc-viewer/example/index
            but I can not convert it into another format.
            There ist a downloadbutton and a dropbox button but they do not work
            what can I do?
            can somebody convert for me?
            http://www.zz7.de
              Can you open the file with this...
              Open IFC Viewer
              (openifcviewer.com)
              Also try this...
              Page not found · GitHub Pages
              (www.ifcopenshell.org)
                jo-ke
                can I convert with it or only open it?
                opening works fine with the first one but I was not able to convert it.
                http://www.zz7.de
                  The first is a viewer only. It's to see if the file will actually open.
                  The second allows you to convert. I was interested to see if the file itself would open elsewhere.
                    jo-ke
                    Open IFC Viewer
                    (openifcviewer.com)
                    Also try this...
                    first one: I can open it but the grafic look s wired. Not option to export to collada
                    second one: installation failed but description sounds interessting. Tried to install different versions, all failed.
                    http://www.zz7.de
                      I'm out of options I'm afraid.
                      Ask your client to export to a different format. IFC can be hit or miss because its not just mesh data and that is likely all you need.
                        jo-ke
                        My client was able to convert to sketchup.
                        thank you
                        http://www.zz7.de
                          Out of curiosity, what did that 120mb .ifc become in size when converted to .skp
