    Where have my plugins gone?
    5 Posts 3 Posters 2.4k Views 3 Watching
      I just downloaded SU Pro 2022 and all my plugins have gone and are not mentioned in my extensions manager. Where do I go from here?
        Every new install of SketchUp Pro requires you to migrate your plugins.
          Thanks Rich, I expected them to be in (C) Program data/sketchup/Sketchup2021/plugins but only plugins i cab see there is twinm,otion direct ling and no others
            C;\Users\USERNAME\AppData\Roaming\SketchUp\SketchUp 2021\SketchUp\Plugins
            If you are on Windows. On MAC its likely similar just more precious and special
              Don't copy your extensions from an older installation of SketchUp unless you enjoy chasing loading errors. Some extensions require the proper installation method, some need to be updated to run in the new SketchUp version. Best to install them fresh from their sources. If you used the Sketchucation Extension Store tool to install extensions from here, install it first. Open it up and sign in. Then click on the gear icon at the top and go to Bundles. You can install the latest versions of the extensions in your bundle automatically without having to search for them all.
