    UnZIP Error : Could not unzip archive.
    25 Posts 9 Posters 7.4k Views 9 Watching
      The new filter you mentioned further up is likely the culprit.
      Maybe poke around it and see if it is overzealous with it's blacklisting.
        At least give us some clues what is this 'new filter' ?
        It will have settings which you need to check aren't blocking SketchUcation or the IP address numbers Gábor gave you...
        Who installed it ?
        Does it have any instructions ??
        If we had more information we might be able to help you better, but if you leave us in the dark then you'll get no where...
          sashapepperspray
          I will message the makers of this filter, and see if I can work it out. Thank you for your help, I will post here again after speaking to them.
            sashapepperspray
            I spoke to them, and we fixed it, so everything is working fine now. Than you everyone for your imput on this.
              minsoeyarzar
              End of Support policy
              End of Support affects all SketchUp products installed on your desktop PC or Mac. When "End of Support" happens, the product you are using goes from being "Supported" to "Unsupported". Going forward, SketchUp desktop products will become unsupported on January 31st of the third year after the product's release year. For example, SketchUp 2022's End of Support date is January 31, 2025.
              when i used the sketchup 19 it got expired and reinstall can't be complete with fredo latest version, so i had installed the skechup 23 verion and used the fredo6 plugins (animator) are easy to enable.
              • 2 / 2
