    UnZIP Error : Could not unzip archive.
    25 Posts 9 Posters 8.4k Views 9 Watching
      Did you correctly install SketchUp? That requires right clicking on the downloaded installer and choosing Run as administrator.
        sashapepperspray
        This used to work until recently (maybe a month ago?) and I haven't reinstalled sketchup since then. (Although I got a new filter on my computer around that time, but I don't remember what happened first, the filter or the unzipping problem)
          Gábor
          Please check if at your firewall ( filter? ) settings all sketchucation servers ( *.sketchucation.com ) and IP addresses ( 178.63.47.155, 144.76.69.227 ) are whitelisted.
            sashapepperspray
            I have repaired my installation, cleared by microsoft edge cache, and nothing change. I am able to go to pluginstore.sketchucation.com through a browser, so I don't think it is blocked. any more ideas?
              sashapepperspray
              any ideas?
                Did you check/do Gábor's whitelisting ideas ?
                  sashapepperspray
                  how do I check this?
                  • Rich O BrienR Online
                    The new filter you mentioned further up is likely the culprit.
                    Maybe poke around it and see if it is overzealous with it's blacklisting.
                      At least give us some clues what is this 'new filter' ?
                      It will have settings which you need to check aren't blocking SketchUcation or the IP address numbers Gábor gave you...
                      Who installed it ?
                      Does it have any instructions ??
                      If we had more information we might be able to help you better, but if you leave us in the dark then you'll get no where...
                        sashapepperspray
                        I will message the makers of this filter, and see if I can work it out. Thank you for your help, I will post here again after speaking to them.
                          sashapepperspray
                          I spoke to them, and we fixed it, so everything is working fine now. Than you everyone for your imput on this.
                            minsoeyarzar
                            End of Support policy
                            End of Support affects all SketchUp products installed on your desktop PC or Mac. When "End of Support" happens, the product you are using goes from being "Supported" to "Unsupported". Going forward, SketchUp desktop products will become unsupported on January 31st of the third year after the product's release year. For example, SketchUp 2022's End of Support date is January 31, 2025.
                            when i used the sketchup 19 it got expired and reinstall can't be complete with fredo latest version, so i had installed the skechup 23 verion and used the fredo6 plugins (animator) are easy to enable.
                            • 2 / 2
