Challenge
I am gonna give this model a go. But who can do this fast and easy and still good looking?
My attempt...
Very basic proxy mesh....
...with a level of SUbD....
...for the texture I just projected your photo...
Super work Rich
Wow, just incredible soliution!
Wow Rich! Cannot beat that
I think I give up. Impressing modelling indeed. Thank you for showing. -
Bravo to Epix3D for trying the model and super bravo to Rich for his example !
great both, the task and Rich's solution!
Great job Rich.
Just curious Rich. How do you know how to split model(divide) and do you model half as component before combining and subdivision?
Did you use a plugin for texturing? (i.e FredoΒ΄s Thrupaint) -
I began with the cow/bull horns and decided on 8 segments for the profile. This meant I had some idea of the volume needed to create the head portion. I did only model half and mirror it. But because the photo was not completely straight I exploded the geometry and tweaked the mirrored side to match the photo.
It was more point to point modelling than box modelling.
No, just projection of your photo. I did use Texture > Position on areas where needed. But 90% is projection.
Thank you for explaining..
Here is another one..
My try.
Untill I learn more of subdivision i used Curviloft and scale for this model
