    Area of entity
    6 Posts 4 Posters 2.9k Views 4 Watching
      tspco
      Not exactly new to SketchUp, I have been using it since 2008 or so, however, I am new to SU2021 Pro, the latest version I had was 2017 before upgrading. I found out that the layers are now called Tags but in the entity info "area" is missing. Is this gone or just hiding?
      SU make 2017, /Twilight Render Hobby
      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
      • BoxB Offline
        Make sure you are only selecting a face, if you select the face and edges it won't show.
          As it has always been, area is only shown in Entity Info if you have a face or faces selected.
          Please update your profile. It shows you are still using SketchUp 2013.
            tspco
            Profile updated and I found the area, thanks Dave, Merry Christmas!
              Area.jpgI just use Tools/Text, click on the surface. SU pro 2021
                That can be useful although you then need to either escape or undo the label if you don't want to leave it there.
