    Pool water with caustics
    renderpluginsextensions
    3 Posts 3 Posters 7.6k Views 3 Watching
    • L
      ledisnomad
      I don't render pool water very often, but every time I do, it takes me forever to figure out how to get the caustics to work. I go through all the settings, search for all the tutorials.
      I just started another project with a pool and I'm going to want a rendering with awesome pool water caustics.
      Here's what I'm doing:
      • Creating a plane that is the surface of the water and making it a component.
      • Applying a water material to the component and to both faces of the plane.
      • Adding a displacement geometry modifier to the component - I use the same noise map from the water Bump channel for the displacement.
      • In the water material Refraction Advanced Settings, uncheck "Affect Shadows".
      • In the render settings Global Illumination Advanced Settings, turn on "Photon Mapped Caustics".
      What am I missing? You'll see in the image that the displacement is working at least.
      • R
        rv1974
        If it was in Max, I'd say it's Photon radius in Sun settings. Just repeate some of YT tutorials
        • F
          freebs
          [attachment=0:2gykd0yy]<!-- ia0 -->pool.jpg<!-- ia0 -->[/attachment:2gykd0yy]
          I think you also need to be in CPU mode for the caustics to work.
