    Import error with gltf importer
    6 Posts 3 Posters 3.7k Views 3 Watching
    • J
      j_jones
      I wanted to import a terrain from sketchfab and tried with two different models:
      https://sketchfab.com/3d-models/american-road-9558c1673bff4ec7b1c7154e4826699e
      and
      https://sketchfab.com/3d-models/sea-cliffs-4-add5edc7a72940bcbd898d74e8402665
      Both fail with "Import Error"
      Has anyone seen this error?
      Here is the stack trace:
      Import has failed. Details as follows:
      #<TypeError; reference to deleted Group>
      Backtrace;
      	/users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe;365;in `entities'
      	/users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe;365;in `create_mesh'
      	/users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe;209;in `import_node'
      	/users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe;232;in `block in import_node'
      	/users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe;230;in `each'
      	/users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe;230;in `import_node'
      	/users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe;99;in `block in import'
      	/users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe;97;in `each'
      	/users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe;97;in `import'
      	/users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_import.rbe;30;in `load_file'
      Thanks for any advice
      -J_Jones
      edit: Just happened upon this one: https://github.com/YulioTech/SketchUp-glTF-Importer-Ruby
      not sure how to install it for OSX or if it will make any difference.
      Thanks for thoughts or advice
        Are you using the importer you linked to?
        The path to the linked importer is
        AppData\Roaming\SketchUp\SketchUp 2021\SketchUp\Plugins\yulio_gltf_import
        Your error output lists
        which to me seems to be a different extension
        • J
          j_jones
          To Rich O Brien
          I mentioned the github link as a P.S. afterthought. I didn't mean to confuse anyone.
          The error came from the Centaur plugin.
            To J Jones
            I can't say why it outputs that many errors. Maybe incompatibility with SU2017? Did you try it in a trial 2021 version?
            • S
              slbaumgartner
              From the stack trace as well as your profile, you are on a Mac. But the capitalization of the items in the path is not standard. Are you perhaps running macOS on a case-sensitive filesystem (not the default)? There have been numerous strange issues reported in the past when SketchUp is installed on a case-sensitive filesystem.
              • J
                j_jones
                Thanks for the info, I'm not sure, but I haven't done anything special to this mac. I think it's just the default. As far as I can tell, it is case insensitive.
                File System Personality: APFS
                Type (Bundle): apfs
                Name (User Visible): APFS
                Anyway, maybe it just ran out of memory or maybe I'll try that other plugin I found.
                -J Jones
