    Import error with gltf importer
    6 Posts 3 Posters 3.5k Views 3 Watching
      j_jones
      I wanted to import a terrain from sketchfab and tried with two different models:
      https://sketchfab.com/3d-models/american-road-9558c1673bff4ec7b1c7154e4826699e
      and
      https://sketchfab.com/3d-models/sea-cliffs-4-add5edc7a72940bcbd898d74e8402665
      Both fail with "Import Error"
      Has anyone seen this error?
      Here is the stack trace:
      Import has failed. Details as follows:
      #<TypeError; reference to deleted Group>
      Backtrace;
      	/users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe;365;in `entities'
      	/users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe;365;in `create_mesh'
      	/users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe;209;in `import_node'
      	/users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe;232;in `block in import_node'
      	/users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe;230;in `each'
      	/users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe;230;in `import_node'
      	/users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe;99;in `block in import'
      	/users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe;97;in `each'
      	/users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_importer.rbe;97;in `import'
      	/users/foo/library/application support/sketchup 2017/sketchup/plugins/centaur_gltf_import/gltf_import.rbe;30;in `load_file'
      Thanks for any advice
      -J_Jones
      edit: Just happened upon this one: https://github.com/YulioTech/SketchUp-glTF-Importer-Ruby
      not sure how to install it for OSX or if it will make any difference.
      Thanks for thoughts or advice
      • Rich O BrienR Online
        Are you using the importer you linked to?
        The path to the linked importer is
        AppData\Roaming\SketchUp\SketchUp 2021\SketchUp\Plugins\yulio_gltf_import
        Your error output lists
        which to me seems to be a different extension
          j_jones
          To Rich O Brien
          I mentioned the github link as a P.S. afterthought. I didn't mean to confuse anyone.
          The error came from the Centaur plugin.
            To J Jones
            I can't say why it outputs that many errors. Maybe incompatibility with SU2017? Did you try it in a trial 2021 version?
              slbaumgartner
              From the stack trace as well as your profile, you are on a Mac. But the capitalization of the items in the path is not standard. Are you perhaps running macOS on a case-sensitive filesystem (not the default)? There have been numerous strange issues reported in the past when SketchUp is installed on a case-sensitive filesystem.
                j_jones
                Thanks for the info, I'm not sure, but I haven't done anything special to this mac. I think it's just the default. As far as I can tell, it is case insensitive.
                File System Personality: APFS
                Type (Bundle): apfs
                Name (User Visible): APFS
                Anyway, maybe it just ran out of memory or maybe I'll try that other plugin I found.
                -J Jones
