    Model Info and Preferences Windows not displaying
    11 Posts 3 Posters 3.6k Views 3 Watching
      smb5823
      Model Info and Preferences Windows not displaying says it all.
      When I go to Window/Model Info the dialog does not open
      Same with window/Preferences dialog
      When Starting Sketchup 2021 I get a Message saying '\one or more of your File Location Paths are invalid. Please correct this by going to Sketchup's Preferences > Files and specify a valid path for any items shown in red.'
      Anybody else seen this?
      If yes, how did you fix?
        Do you use dual monitors?
        Do you hear the Windows bing noise if you click the SketchUp viewport? That would be a sign the dialog is active just likely off screen.
          Another clue would be the Menu greyed out...
          https://i.imgur.com/ZcFR2ci.png
            smb5823
            Rich
            I have a 3 monitor setup and I do get the 'bing' you describe when clicking on the screen.
            If the dialog is 'offscreen', is there a way to get it relocated 'onscreen'?
            Dave
            My install procedure is 'run as administrator' followed by a reboot.
              Right click the Taskbar and choose Cascade Windows...
              https://i.imgur.com/JOXUI49.png
              ...see if that forces the dialog to relocate.
              As for the path warning that's more concerning
                smb5823
                Dave
                Tried a 'run as administrator' and 'repair'.
                Rebooted and am still getting the error message.
                Rich
                Cascade Windows did not work unfortunately. Any other ideas or should I try a 'fresh install'?
                  I think Big Dave's Repair, or your Reinstall, is a good solution that should at least reset the dialogs.
                  But that path issue, did that just happen or did you relocate paths or move locations? That has me intrigued...
                    smb5823
                    I did format one of my hard drives the other day, and it's happened ever since. Didn't think I'd pointed any Sketchup paths to that drive though
                      It could be related. Especially if some rarely used folder was pointing there.
                      Try Repair before Reinstall.
                        smb5823
                        Repair didn't solve either issue.
                        A Fresh Install did..... Yay
                        Thanks for your advice, much appreciated Guys
                        • BoxB Offline
                          For future reference there is a key combination that lets you grab any offscreen dialog and move it into view.
                          So with the focus on Preferences (in other words you have tried to open it and the machine is going bing) press alt and spacebar together, then tap m once (where m is move in your language, would be d in french for example) then tap any arrow key and without clicking move the mouse around until the Dialog appears on screen.
                          Once you have Preferences you can use the Reset Workspace button which should bring all dialogs back to the screen.
