    Issue: DCs options window always on top
    3 Posts 2 Posters 2.9k Views 2 Watching
    • P
      pibuz
      Hi all!
      So, this is a small issue I encountered with the latest version of SU.
      In our firm we work a lot with DCs, so we do a lot of options window checks: when I have a component selected and I recall the options window, that automatically becomes the active window, so we cannot input via keyboard any SU command (e.g. M for move, S for scale,...) until we re-select the component, or orbit a little..
      This is a very small misbehaviour, but still a big hassle if you work with DCs.
      Is there a workaround or a fix for this?
      Thanks in advance!
      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
        When a dialog takes focus then the viewport loses it. Unless they implement a GUI like Fredo does that resides in the viewport I would say this extra click will always be there.
        If you are on Windows give X-mouse controls a try...
        X-Mouse Controls by Joel Purra
        Microsoft Windows utility to manage the active window tracking/raising settings. This is known as x-mouse behavior or focus follows mouse on Unix and Linux systems.
        X-Mouse Controls by Joel Purra (joelpurra.com)
        On mutli-monitor setups I use it to focus to the app my mouse is over. Just set the delay between 100-300ms
        I believe it won't work for DC dialog though. So kinda of a pointless recommendation for your issue... 😐
        • P
          pibuz
          Thanks a lot Rich!
          ..I am reporting because it was different since not a long time ago!
          They must have changed a bit somewhere, unconscius that they were causing this (little) drawback.
          I was wondering if the behaviour could be switched back πŸ˜„
