    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    536 Posts 101 Posters 593.3k Views 99 Watching
    • fredo6F
      fredo6
      @rv1974 said:
      Somehow I completely missed πŸ˜„ the the feature of custom toolbars (I thought the palettes were the only option for icons).. Anyway I built a custom toolbar of 50 icons and experienced very long loading times (approx 1+ sec for icon) - so it took 1 minute to load this toolbar.
      Palettes loading times are much better.
      This is a known problem in Sketchup, which has already been logged to Trimble. Displaying a custom toolbar outside of the startup sequence takes long on Windows. I have the same issue on my laptop. There is no workaround currently.
      • fredo6F
        fredo6
        NEW RELEASE: LordOfTheToolbars v1.8d - 02 Feb 22
        Requirements
        • LibFredo6: v12.4a or above
        LordOfTheToolbars 1.8d includes
        • Bug fixing for palette and personal commands shortcuts (which could make palette popup when typing in tray dialogs)
        Home Page of LordOfTheToolbars for information and Download.
        Main post of this LordOfTheToolbars thread.
        • A
          AISmebel
          Hello. Forgive me for torturing you, but in addition to the old error, I found another new error. I can't press the "menu" button. Can't create new icons and can't edit old ones((
          Error: #<RangeError: invalid codepoint 0xD83D in UTF-8>
          c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5383:in all_menus' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5383:in menu_mapping'
          c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5459:in menu_structured_list' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:1056:in menu_compute_list'
          c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:480:in dialog_format_menu_list' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:411:in dialog_format_properties'
          c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:329:in dialog_prepare_html' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:263:in dialog_load_html'
          c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:181:in dialog_invoke' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmanager.rbe:4959:in perso_dialog_invoke'
          c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmasterdialog.rbe:4453:in perso_new_command' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmasterdialog.rbe:2465:in dialog_callback_exec'
          c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmasterdialog.rbe:2322:in dialog_callback' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2385:in call'
          c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2385:in master_callback' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2173:in j_action'
          c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2132:in j_callback' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2118:in block in j_dispatch'
          c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2110:in each' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2110:in j_dispatch'
          • fredo6F
            fredo6
            This UTF8 error is puzzling.
            I don't know if it is related to your Cyrillic environment.
            Also, which version of Windows do you run?
            • A
              AISmebel
              After all, there were no problems before (((
              Windows 10 Pro v.20H2
              • fredo6F
                fredo6
                What was your environment 'before' when it worked?
                • R
                  rv1974
                  Fredo if you already implemented double space-bar for Repeat last.. Is it theoretically possible to implement 2-letter shortcuts via plugin (LOTT)?
                  Like in Revit, for example PB for Profile Builder? I always wanted this feature in SU
                  • A
                    AISmebel
                    Exactly the same. Didn't do Windows updates.
                    Again, everything stopped working after a bug in SketchUp.
                    I will continue to use your plugin anyway πŸ˜„
                    • fredo6F
                      fredo6
                      But what was this bug?
                      • A
                        AISmebel
                        I don’t remember what error caused SketchUp to close. But that was in SU 2020. Then I installed SU 2022 and your plugin still doesn't work 😞
                        • fredo6F
                          fredo6
                          Would you mind to do a Repair of SU2022 to see if this fixes the problem.
                          Same for SU2020 if you still have it on your computer.
                          • A
                            AISmebel
                            Does your plugin share a file that is referenced by SU 2020 and SU 2022?
                            Maybe a settings file? Or something in the registry? Perhaps there was an error and this file needs to be updated.
                            SU 2022 has already done recovery. It didn't help me.
                            • fredo6F
                              fredo6
                              The error is in Sketchup: some menu texts are wrongly encoded (or are read as such). I don't think this is directly related to LOTT.
                              Another user has a similar problem, running a French version of Sketchup 2021, but only on one computer.
                              • alexpacio2013A
                                alexpacio2013
                                Hi, I use the Lord of the toolbar program with satisfaction But since yesterday I have this error message which in any case does not prevent me from continuing to work. the error presents us at the Start of SketchUp, I would like to know what it is from and how to solve it, given the great usefulness of this program for me who are disabled.
                                some extensions are referenced in palettes but not loaded - unknown command sketchup
                                • fredo6F
                                  fredo6
                                  The latest version of LOTT tracks command icons of extensions which are referenced in palettes but are no longer present (for instance, when you uninstall them, or when you import configuration from another version of Sketchup. It displays a notification at startup if there are some, usually indicating the name of the command and extension.
                                  It might be that there is a problem there. I'll have a look.
                                  Fredo
                                  • alexpacio2013A
                                    alexpacio2013
                                    AcZCw6vyeZ.pngWithout this plugin I can't work with skp, congratulations. how can I solve this problem? thanks, skp 2022 fredo lib updated.
                                    • fredo6F
                                      fredo6
                                      It may not be a problem actually. The notification automatically disappears after a few seconds.
                                      Do you have issue with LOTT, in particular about 'ghost icons', that is icons in palettes that would have a rounded rectangle around and are disabled?
                                      • alexpacio2013A
                                        alexpacio2013
                                        I managed to solve the problem by uninstalling and deleting all the temporary files created by Fredo πŸ˜„ \ Users \ xxx \ AppData \ Local \ LIBFREDO6_DATA_Dir \ LOTT \ GHOST now I no longer have the error at startup
                                        But now Fredo Corner no longer works, with a regular license. I deduce that the problem is caused by the combination of Lord of toolbars v12.5a with fredo Corner v2.5a.
                                        I await updates
                                        • fredo6F
                                          fredo6
                                          NEW RELEASE: LordOfTheToolbars v2.0a - 24 Feb 22
                                          Requirements
                                          LordOfTheToolbars 2.0a includes
                                          • Adjustment for notification at startup of Sketchup
                                          • R
                                            resetarionut
                                            Hi fredo6,
                                            I am also having a problem with LOT, not a big one but the plugin is not loding with sketchup, I have to manualy open it by navigationg to tools>fredo6>LOT>Master Toolbar Manager, or any other menu that forces LOT to start, and my custom toolbars lose placement, the toolbars are reseting to floating toolbars.
                                            I have sketchup 2022 on windows 10, everytinh is up to date.
                                            It worked before the latest update.
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 26
                                            • 27
                                            • 9 / 27
