    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    558 Posts 101 Posters 689.7k Views 99 Watching
    • fredo6F
      You seem to have 2 problems
      1. The Vignette Stripe does not display
      2. The custom toolbars are not showing at startup, but later on
      I don't have an explanation for that. I will probably need to send you a special version with traces to find out what is the problem.
      In the meantime, could you
      • Open the Ruby console
      • Close Sketchup with the Ruby console opened
      • restart Sketchup
      • Check if some errors appear in the Ruby console
        AISmebel
        1. The custom toolbars are not showing at startup, but later on
        • restart Sketchup
        "Add help menu!"
        "create new"
        "created"
        #Sketchup::Menu:0x0000023c232015f0
        This inscription appeared a minute after the launch of SU. And after I opened the console on my own.
        Ruby console didn't open automatically!
        • fredo6F
          Is this something happening only in SU2022.?
            AISmebel
            The problem first appeared on SU 2020. A week later I installed SU 2022. And migrated all the plugins to SU 2022, uninstalled LordOfTheToolbars and reinstalled it with the latest version of the plugin. SU 2022 and SU 2020 have the same problem.
            • fredo6F
              @AISmebel
              I sent you a modified version of LOTT by Private message. This version includes traces at startup, so that I can find out what is going on.
                rv1974
                Somehow I completely missed πŸ˜„ the the feature of custom toolbars (I thought the palettes were the only option for icons).. Anyway I built a custom toolbar of 50 icons and experienced very long loading times (approx 1+ sec for icon) - so it took 1 minute to load this toolbar.
                Palettes loading times are much better.
                  AISmebel
                  You're right. Long loading panels are a little annoying)))
                  But this version of the panels suits me better.
                  • fredo6F
                    This is a known problem in Sketchup, which has already been logged to Trimble. Displaying a custom toolbar outside of the startup sequence takes long on Windows. I have the same issue on my laptop. There is no workaround currently.
                    • fredo6F
                      NEW RELEASE: LordOfTheToolbars v1.8d - 02 Feb 22
                      Requirements
                      • LibFredo6: v12.4a or above
                      LordOfTheToolbars 1.8d includes
                      • Bug fixing for palette and personal commands shortcuts (which could make palette popup when typing in tray dialogs)
                      Home Page of LordOfTheToolbars for information and Download.
                      Main post of this LordOfTheToolbars thread.
                        AISmebel
                        Hello. Forgive me for torturing you, but in addition to the old error, I found another new error. I can't press the "menu" button. Can't create new icons and can't edit old ones((
                        Error: #<RangeError: invalid codepoint 0xD83D in UTF-8>
                        c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5383:in all_menus' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5383:in menu_mapping'
                        c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5459:in menu_structured_list' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:1056:in menu_compute_list'
                        c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:480:in dialog_format_menu_list' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:411:in dialog_format_properties'
                        c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:329:in dialog_prepare_html' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:263:in dialog_load_html'
                        c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:181:in dialog_invoke' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmanager.rbe:4959:in perso_dialog_invoke'
                        c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmasterdialog.rbe:4453:in perso_new_command' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmasterdialog.rbe:2465:in dialog_callback_exec'
                        c:/programdata/sketchup/sketchup 2020/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmasterdialog.rbe:2322:in dialog_callback' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2385:in call'
                        c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2385:in master_callback' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2173:in j_action'
                        c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2132:in j_callback' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2118:in block in j_dispatch'
                        c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2110:in each' c:/programdata/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2110:in j_dispatch'
                        • fredo6F
                          This UTF8 error is puzzling.
                          I don't know if it is related to your Cyrillic environment.
                          Also, which version of Windows do you run?
                            AISmebel
                            After all, there were no problems before (((
                            Windows 10 Pro v.20H2
                            • fredo6F
                              What was your environment 'before' when it worked?
                                rv1974
                                Fredo if you already implemented double space-bar for Repeat last.. Is it theoretically possible to implement 2-letter shortcuts via plugin (LOTT)?
                                Like in Revit, for example PB for Profile Builder? I always wanted this feature in SU
                                  AISmebel
                                  Exactly the same. Didn't do Windows updates.
                                  Again, everything stopped working after a bug in SketchUp.
                                  I will continue to use your plugin anyway πŸ˜„
                                  • fredo6F
                                    But what was this bug?
                                      AISmebel
                                      I don’t remember what error caused SketchUp to close. But that was in SU 2020. Then I installed SU 2022 and your plugin still doesn't work 😞
                                      • fredo6F
                                        Would you mind to do a Repair of SU2022 to see if this fixes the problem.
                                        Same for SU2020 if you still have it on your computer.
                                          AISmebel
                                          Does your plugin share a file that is referenced by SU 2020 and SU 2022?
                                          Maybe a settings file? Or something in the registry? Perhaps there was an error and this file needs to be updated.
                                          SU 2022 has already done recovery. It didn't help me.
                                          • fredo6F
                                            The error is in Sketchup: some menu texts are wrongly encoded (or are read as such). I don't think this is directly related to LOTT.
                                            Another user has a similar problem, running a French version of Sketchup 2021, but only on one computer.
                                            • 11
                                            • 27
                                            • 28
                                            • 9 / 28
