[Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
I think this is an issue with one extension which uses diacritic characters in the menu item label.
Maybe Universal Importer by samuel_t, or one of his other plugins.
Best is to check in the submenu of the Extensions menu.
Fredo
Fredo
Fredo, thank you for your help and all your wonderful plugins.
I unistall the universal importer and all worked fine.
Best Regards.
Hi I have updated the LortdOfTheToolbars Plugins and from that moment every time I open Sketchup and my menu bars do not go out. To do this I have to launch Master toolbar Manager and they automatically open What can I do?
@alexpacio2013 said:
Hi I have updated the LortdOfTheToolbars Plugins...
What version of SketchUp are you using? Your profile says "pre-2013". Is that correct?
@Dave you should make "What version of SketchUp are you using?" your signature
Could it be written in CNC landuage? -
After the update of LordOfTheToolbars - v2.2a - 28 Jun 22, now every time I open Sketchup, the menu bars of LordOfTheToolbars are not opened. However, if I open Master Toolbars Manager, the toolbars magically open, see image. What happened?
1659777819.050634;top_libfredo6.rbe:171: in `open'
DATE / TIME: 2022-08-06 11:23:39 +0200
SKETCHUP VERSION: 22.0.354
RUBY_PLATFORM: x64-mswin64_140
LOG FILE: LibFredo6Trace_22_1659777819048.txt1659777819.0502865;top_libfredo6.rbe:171: in `open'
LibFredo6: Starting up Fredo6_!LibFredo6.rb1659777819.0514805;top_libfredo6.rbe:171: in `open'
LibFredo6 Root top directory: C:/Users/robo/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins1659777819.0598936;top_libfredo6.rbe:171: in `open'
APPDATA Sketchup directory: C:/Users/robo/AppData/Local1659777819.0603428;top_libfredo6.rbe:171: in `open'
Temp Files directory: C:/Users/robo/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles1659777819.062464;top_libfredo6.rbe:171: in `open'
LibFredo6 Data directory folder: C:/Users/robo/AppData/Local/LIBFREDO6_DATA_Dir1659777819.0628412;top_libfredo6.rbe:171: in `open'
Default Parameters folder: C:/Users/robo/AppData/Local/LIBFREDO6_DATA_Dir/DefaultParameters1659777819.063465;top_libfredo6.rbe:171: in `open'
LibFredo6: Beginning of loading Cycle***+1659777819.0766423;top_libfredo6.rbe:171: in `open'
LibFredo6 Core: Fredo6_!LibFredo6/Lib6Core successfully loaded1659777819.106217;top_libfredo6.rbe:171: in `open'
LibFredo6 12.9a: Effective Load - #01659777819.297847;top_libfredo6.rbe:171: in `open'
LibFredo6 12.9a: Ruby files loaded [189 ms]1659777819.3327165;top_libfredo6.rbe:171: in `open'
add Command Seleziona Lingua preferita...1659777819.333846;top_libfredo6.rbe:171: in `open'
add Command Controlla aggiornamenti Plugins...1659777819.3347752;top_libfredo6.rbe:171: in `open'
add Command Purge Obsolete files...1659777819.3356633;top_libfredo6.rbe:171: in `open'
add Command Performances...1659777819.3365421;top_libfredo6.rbe:171: in `open'
add Command View Trace log files...1659777819.3375835;top_libfredo6.rbe:171: in `open'
add Command Informazioni LibFredo6 v12.9a...1659777819.3420873;top_libfredo6.rbe:171: in `open'
add Command Informazione Plugin [Sketchucation]...1659777819.3435683;top_libfredo6.rbe:171: in `open'
add Command Modifica parametri di Default...1659777819.3444655;top_libfredo6.rbe:171: in `open'
add Command Traduzione Lingue...1659777819.345387;top_libfredo6.rbe:171: in `open'
LibFredo6 12.9a: Startup (creating menus and icons) [46 ms]1659777819.35002;top_libfredo6.rbe:171: in `open'
Found valid plugin: LordOfTheToolbars1659777819.3885655;top_libfredo6.rbe:171: in `open'
Found valid plugin: Animator1659777819.3910367;top_libfredo6.rbe:171: in `open'
Found valid plugin: Curviloft1659777819.3933218;top_libfredo6.rbe:171: in `open'
Found valid plugin: Curvizard1659777819.3955631;top_libfredo6.rbe:171: in `open'
Found valid plugin: FredoCorner1659777819.3977685;top_libfredo6.rbe:171: in `open'
Found valid plugin: FredoGuides1659777819.4000278;top_libfredo6.rbe:171: in `open'
Found valid plugin: FredoScale1659777819.402219;top_libfredo6.rbe:171: in `open'
Found valid plugin: FredoSpline1659777819.404525;top_libfredo6.rbe:171: in `open'
Found valid plugin: FredoTools1659777819.4067292;top_libfredo6.rbe:171: in `open'
Found valid plugin: HoverSelect1659777819.4090075;top_libfredo6.rbe:171: in `open'
Found valid plugin: JointPushPull1659777819.4111617;top_libfredo6.rbe:171: in `open'
Found valid plugin: MoveAlignMe1659777819.4133294;top_libfredo6.rbe:171: in `open'
Found valid plugin: MrHide1659777819.415562;top_libfredo6.rbe:171: in `open'
Found valid plugin: ToolsOnSurface1659777819.4176936;top_libfredo6.rbe:171: in `open'
Found valid plugin: VisuHole1659777819.6108224;top_libfredo6.rbe:171: in `open'
Plugin to Load [0]: ["LordOfTheToolbars", "!!Fredo6_LordOfTheToolbars"]1659777819.61143;top_libfredo6.rbe:171: in `open'
Plugin to Load [1]: ["Animator", "Fredo6_Animator"]1659777819.6119018;top_libfredo6.rbe:171: in `open'
Plugin to Load [2]: ["Curviloft", "Fredo6_Curviloft"]1659777819.6123133;top_libfredo6.rbe:171: in `open'
Plugin to Load [3]: ["Curvizard", "Fredo6_Curvizard"]1659777819.6127267;top_libfredo6.rbe:171: in `open'
Plugin to Load [4]: ["FredoCorner", "Fredo6_FredoCorner"]1659777819.6131077;top_libfredo6.rbe:171: in `open'
Plugin to Load [5]: ["FredoGuides", "Fredo6_FredoGuides"]1659777819.613492;top_libfredo6.rbe:171: in `open'
Plugin to Load [6]: ["FredoScale", "Fredo6_FredoScale"]1659777819.6138604;top_libfredo6.rbe:171: in `open'
Plugin to Load [7]: ["FredoSpline", "Fredo6_FredoSpline"]1659777819.6142204;top_libfredo6.rbe:171: in `open'
Plugin to Load [8]: ["FredoTools", "Fredo6_FredoTools"]1659777819.6145978;top_libfredo6.rbe:171: in `open'
Plugin to Load [9]: ["HoverSelect", "Fredo6_HoverSelect"]1659777819.6149728;top_libfredo6.rbe:171: in `open'
Plugin to Load [10]: ["JointPushPull", "Fredo6_JointPushPull"]1659777819.6153467;top_libfredo6.rbe:171: in `open'
Plugin to Load [11]: ["MoveAlignMe", "Fredo6_MoveAlignMe"]1659777819.6157293;top_libfredo6.rbe:171: in `open'
Plugin to Load [12]: ["MrHide", "Fredo6_MrHide"]1659777819.6160994;top_libfredo6.rbe:171: in `open'
Plugin to Load [13]: ["ToolsOnSurface", "Fredo6_ToolsOnSurface"]1659777819.6164649;top_libfredo6.rbe:171: in `open'
Plugin to Load [14]: ["VisuHole", "Fredo6_VisuHole"]1659777819.8602266;top_libfredo6.rbe:171: in `open'
LordOfTheToolbars 2.2a: Effective Load - #11659777819.8711247;top_libfredo6.rbe:171: in `open'
LordOfTheToolbars: Seed file created1659777819.87369;top_libfredo6.rbe:171: in `open'
LordOfTheToolbars: COPIED SEED C:/ProgramData/SketchUp/SketchUp 2022/SketchUp/Plugins/!LordOfTheToolbars_seed.rb exist = true1659777819.874354;top_libfredo6.rbe:171: in `open'
LordOfTheToolbars 2.2a: Bootstrap Ruby files loaded [13 ms]1659777819.8949528;top_libfredo6.rbe:171: in `open'
add Command Master Toolbar Manager1659777819.897017;top_libfredo6.rbe:171: in `open'
add Command Favorite Manager1659777819.8990428;top_libfredo6.rbe:171: in `open'
add Command History Palette1659777819.9010985;top_libfredo6.rbe:171: in `open'
add Command Navigate History1659777819.9030466;top_libfredo6.rbe:171: in `open'
add Command Last command1659777819.9049275;top_libfredo6.rbe:171: in `open'
add Command Toggle visibility of the Vignette stripe1659777819.9073923;top_libfredo6.rbe:171: in `open'
add Command Reset the Vignette Stripe position1659777819.909998;top_libfredo6.rbe:171: in `open'
add Command Pop up the Vignette Stripe1659777819.912691;top_libfredo6.rbe:171: in `open'
add Command Cycle through Palettes1659777819.9152055;top_libfredo6.rbe:171: in `open'
add Command Quick Command Finder1659777819.9175193;top_libfredo6.rbe:171: in `open'
add Command Backup LOTT Config1659777819.9199433;top_libfredo6.rbe:171: in `open'
add Command Import LOTT Config1659777819.9222531;top_libfredo6.rbe:171: in `open'
add Command Export LOTT Config1659777819.9246366;top_libfredo6.rbe:171: in `open'
add Command Reset All1659777819.9270604;top_libfredo6.rbe:171: in `open'
add Command Reset History1659777819.9294598;top_libfredo6.rbe:171: in `open'
add Command Toggle CleanScreen mode1659777819.9318085;top_libfredo6.rbe:171: in `open'
add Command CleanScreen Configuration1659777819.9341626;top_libfredo6.rbe:171: in `open'
add Command List of all shortuts1659777819.9364662;top_libfredo6.rbe:171: in `open'
add Command Exclude VRay1659777819.9388504;top_libfredo6.rbe:171: in `open'
add Command Informazioni LordOfTheToolbars v2.2a...1659777819.9445026;top_libfredo6.rbe:171: in `open'
add Command Informazione Plugin [Sketchucation]...1659777819.945423;top_libfredo6.rbe:171: in `open'
add Command Controlla aggiornamenti Plugins...1659777819.9468265;top_libfredo6.rbe:171: in `open'
add Command Modifica parametri di Default...1659777819.9477277;top_libfredo6.rbe:171: in `open'
add Command Traduzione Lingue...1659777819.9810462;top_libfredo6.rbe:171: in `open'
LordOfTheToolbars 2.2a: Startup (creating menus and icons) [106 ms]1659777820.384493;top_libfredo6.rbe:171: in `open'
Animator 3.7a: Effective Load - #21659777820.3904972;top_libfredo6.rbe:171: in `open'
Animator 3.7a: Bootstrap Ruby files loaded [5 ms]1659777820.3949382;top_libfredo6.rbe:171: in `open'
Lib6Theme: Loading body code from body_Lib6Theme [3 ms]1659777820.4038517;top_libfredo6.rbe:171: in `open'
add Command Clip Editor1659777820.405462;top_libfredo6.rbe:171: in `open'
add Command Clip Player1659777820.4067729;top_libfredo6.rbe:171: in `open'
add Command Visit Controller1659777820.4081466;top_libfredo6.rbe:171: in `open'
add Command Positioner1659777820.4096053;top_libfredo6.rbe:171: in `open'
add Command Informazioni Animator v3.7a...1659777820.4207933;top_libfredo6.rbe:171: in `open'
add Command Informazione Plugin [Sketchucation]...1659777820.4217577;top_libfredo6.rbe:171: in `open'
add Command Controlla aggiornamenti Plugins...1659777820.4231699;top_libfredo6.rbe:171: in `open'
add Command Modifica parametri di Default...1659777820.4240642;top_libfredo6.rbe:171: in `open'
add Command Traduzione Lingue...1659777820.4625092;top_libfredo6.rbe:171: in `open'
Animator 3.7a: Startup (creating menus and icons) [71 ms]1659777820.471187;top_libfredo6.rbe:171: in `open'
Curviloft 1.9a: Effective Load - #31659777820.4753973;top_libfredo6.rbe:171: in `open'
Curviloft 1.9a: Bootstrap Ruby files loaded [3 ms]1659777820.4819002;top_libfredo6.rbe:171: in `open'
add Command Loft by Spline1659777820.4835315;top_libfredo6.rbe:171: in `open'
add Command Loft along path1659777820.4849508;top_libfredo6.rbe:171: in `open'
add Command Skin Contours1659777820.486353;top_libfredo6.rbe:171: in `open'
add Command Informazioni Curviloft v1.9a...1659777820.487222;top_libfredo6.rbe:171: in `open'
add Command License...1659777820.4880924;top_libfredo6.rbe:171: in `open'
add Command Trial Period Expiration...1659777820.4938774;top_libfredo6.rbe:171: in `open'
add Command Informazione Plugin [Sketchucation]...1659777820.494852;top_libfredo6.rbe:171: in `open'
add Command Controlla aggiornamenti Plugins...1659777820.4963236;top_libfredo6.rbe:171: in `open'
add Command Modifica parametri di Default...1659777820.4973097;top_libfredo6.rbe:171: in `open'
add Command Traduzione Lingue...1659777820.5164933;top_libfredo6.rbe:171: in `open'
Curviloft 1.9a: Startup (creating menus and icons) [40 ms]1659777820.5256727;top_libfredo6.rbe:171: in `open'
Curvizard 2.4b: Effective Load - #41659777820.5323317;top_libfredo6.rbe:171: in `open'
Curvizard 2.4b: Bootstrap Ruby files loaded [5 ms]1659777820.541005;top_libfredo6.rbe:171: in `open'
add Command Quick Launcher...1659777820.5426147;top_libfredo6.rbe:171: in `open'
add Command Make Curves (weld)1659777820.5440307;top_libfredo6.rbe:171: in `open'
add Command Explode Curves1659777820.545435;top_libfredo6.rbe:171: in `open'
add Command Cleanup Contours1659777820.5468512;top_libfredo6.rbe:171: in `open'
add Command Simplify Contours1659777820.5482337;top_libfredo6.rbe:171: in `open'
add Command Smooth Contours1659777820.5496497;top_libfredo6.rbe:171: in `open'
add Command Edge Properties1659777820.5510848;top_libfredo6.rbe:171: in `open'
add Command Convert Edges to Guides1659777820.5525348;top_libfredo6.rbe:171: in `open'
add Command Convert to Arc / Circle1659777820.553985;top_libfredo6.rbe:171: in `open'
add Command Convert to Polygon1659777820.555427;top_libfredo6.rbe:171: in `open'
add Command Informazioni Curvizard v2.4b...1659777820.5563304;top_libfredo6.rbe:171: in `open'
add Command License...1659777820.5576882;top_libfredo6.rbe:171: in `open'
add Command Trial Period Expiration...1659777820.563914;top_libfredo6.rbe:171: in `open'
add Command Informazione Plugin [Sketchucation]...1659777820.5650506;top_libfredo6.rbe:171: in `open'
add Command Controlla aggiornamenti Plugins...1659777820.5668058;top_libfredo6.rbe:171: in `open'
add Command Modifica parametri di Default...1659777820.5678856;top_libfredo6.rbe:171: in `open'
add Command Traduzione Lingue...1659777820.6217778;top_libfredo6.rbe:171: in `open'
Curvizard 2.4b: Startup (creating menus and icons) [88 ms]1659777820.6301749;top_libfredo6.rbe:171: in `open'
FredoCorner 2.5a: Effective Load - #51659777820.6354005;top_libfredo6.rbe:171: in `open'
FredoCorner 2.5a: Bootstrap Ruby files loaded [4 ms]1659777820.6419108;top_libfredo6.rbe:171: in `open'
add Command Round1659777820.6434898;top_libfredo6.rbe:171: in `open'
add Command Bevel1659777820.6449006;top_libfredo6.rbe:171: in `open'
add Command SubDivision1659777820.6463234;top_libfredo6.rbe:171: in `open'
add Command Chop Corner1659777820.6476603;top_libfredo6.rbe:171: in `open'
add Command Repair1659777820.64898;top_libfredo6.rbe:171: in `open'
add Command Purge all data1659777820.6499054;top_libfredo6.rbe:171: in `open'
add Command Informazioni Fredo Corner v2.5a...1659777820.650826;top_libfredo6.rbe:171: in `open'
add Command License...1659777820.6517062;top_libfredo6.rbe:171: in `open'
add Command Trial Period Expiration...1659777820.6563776;top_libfredo6.rbe:171: in `open'
add Command Informazione Plugin [Sketchucation]...1659777820.6572852;top_libfredo6.rbe:171: in `open'
add Command Controlla aggiornamenti Plugins...1659777820.6587155;top_libfredo6.rbe:171: in `open'
add Command Modifica parametri di Default...1659777820.6596198;top_libfredo6.rbe:171: in `open'
add Command Traduzione Lingue...1659777820.6959202;top_libfredo6.rbe:171: in `open'
FredoCorner 2.5a: Startup (creating menus and icons) [60 ms]1659777820.7102923;top_libfredo6.rbe:171: in `open'
FredoScale 3.5a: Effective Load - #61659777820.717813;top_libfredo6.rbe:171: in `open'
FredoScale 3.5a: Bootstrap Ruby files loaded [6 ms]1659777820.7442555;top_libfredo6.rbe:171: in `open'
add Command Quick Launcher...1659777820.7465575;top_libfredo6.rbe:171: in `open'
add Command Box Scalatura1659777820.7489302;top_libfredo6.rbe:171: in `open'
add Command Box Scalatura verso Destinazione1659777820.7512124;top_libfredo6.rbe:171: in `open'
add Command Box Inclinatura1659777820.753441;top_libfredo6.rbe:171: in `open'
add Command Box Inclinatura verso Destinazione1659777820.7556183;top_libfredo6.rbe:171: in `open'
add Command Box Shearing Planare1659777820.757817;top_libfredo6.rbe:171: in `open'
add Command Box Shearing Planare verso Destinazione1659777820.7599664;top_libfredo6.rbe:171: in `open'
add Command Shearing Planare (Libero)1659777820.7621584;top_libfredo6.rbe:171: in `open'
add Command Box Stretching1659777820.764318;top_libfredo6.rbe:171: in `open'
add Command Box Stretching verso Destinazione1659777820.7677734;top_libfredo6.rbe:171: in `open'
add Command Box Twisting1659777820.7698052;top_libfredo6.rbe:171: in `open'
add Command Box Rotazione1659777820.7717674;top_libfredo6.rbe:171: in `open'
add Command Rotazione (Libero)1659777820.7737472;top_libfredo6.rbe:171: in `open'
add Command Bending Radiale (Libero)1659777820.7757032;top_libfredo6.rbe:171: in `open'
add Command Rendi Unico1659777820.778194;top_libfredo6.rbe:171: in `open'
add Command Informazioni FredoScale v3.5a...1659777820.7792869;top_libfredo6.rbe:171: in `open'
add Command License...1659777820.780257;top_libfredo6.rbe:171: in `open'
add Command Trial Period Expiration...1659777820.7861962;top_libfredo6.rbe:171: in `open'
add Command Informazione Plugin [Sketchucation]...1659777820.7871573;top_libfredo6.rbe:171: in `open'
add Command Controlla aggiornamenti Plugins...1659777820.788678;top_libfredo6.rbe:171: in `open'
add Command Modifica parametri di Default...1659777820.7896168;top_libfredo6.rbe:171: in `open'
add Command Traduzione Lingue...1659777820.8383808;top_libfredo6.rbe:171: in `open'
FredoScale 3.5a: Startup (creating menus and icons) [120 ms]1659777820.8477514;top_libfredo6.rbe:171: in `open'
FredoSpline 2.3a: Effective Load - #71659777820.8552005;top_libfredo6.rbe:171: in `open'
FredoSpline 2.3a: Bootstrap Ruby files loaded [6 ms]1659777820.8683937;top_libfredo6.rbe:171: in `open'
add Command Quick Launcher1659777820.8703284;top_libfredo6.rbe:171: in `open'
add Command Create Curves1659777820.8719673;top_libfredo6.rbe:171: in `open'
add Command Edit Curves1659777820.8735292;top_libfredo6.rbe:171: in `open'
add Command Swap Curves1659777820.875027;top_libfredo6.rbe:171: in `open'
add Command Convert Curves1659777820.8765285;top_libfredo6.rbe:171: in `open'
add Command Purge data1659777820.8779967;top_libfredo6.rbe:171: in `open'
add Command Purge All data1659777820.8795464;top_libfredo6.rbe:171: in `open'
add Command Bezier Classic1659777820.8810525;top_libfredo6.rbe:171: in `open'
add Command Bezier Nurbs1659777820.882643;top_libfredo6.rbe:171: in `open'
add Command Local Fit Spline1659777820.8841708;top_libfredo6.rbe:171: in `open'
add Command Global Fit Spline1659777820.8857195;top_libfredo6.rbe:171: in `open'
add Command Polyline1659777820.88723;top_libfredo6.rbe:171: in `open'
add Command Polyline Divider1659777820.8888128;top_libfredo6.rbe:171: in `open'
add Command Polyline Segmentor1659777820.8903725;top_libfredo6.rbe:171: in `open'
add Command Polycorner Generic1659777820.8918214;top_libfredo6.rbe:171: in `open'
add Command Polycorner Arc1659777820.8934803;top_libfredo6.rbe:171: in `open'
add Command Polycorner Squircle1659777820.894999;top_libfredo6.rbe:171: in `open'
add Command Polycorner Bezier1659777820.8965273;top_libfredo6.rbe:171: in `open'
add Command Polycorner Chamfer1659777820.898061;top_libfredo6.rbe:171: in `open'
add Command Polycorner Dog-Bone1659777820.8996205;top_libfredo6.rbe:171: in `open'
add Command Polycorner T-Bone1659777820.9011447;top_libfredo6.rbe:171: in `open'
add Command Courbette1659777820.9026604;top_libfredo6.rbe:171: in `open'
add Command Informazioni FredoSpline v2.3a...1659777820.9036179;top_libfredo6.rbe:171: in `open'
add Command License...1659777820.9045167;top_libfredo6.rbe:171: in `open'
add Command Trial Period Expiration...1659777820.908837;top_libfredo6.rbe:171: in `open'
add Command Informazione Plugin [Sketchucation]...1659777820.909901;top_libfredo6.rbe:171: in `open'
add Command Controlla aggiornamenti Plugins...1659777820.9114738;top_libfredo6.rbe:171: in `open'
add Command Modifica parametri di Default...1659777820.9123995;top_libfredo6.rbe:171: in `open'
add Command Traduzione Lingue...1659777820.9920552;top_libfredo6.rbe:171: in `open'
FredoSpline 2.3a: Startup (creating menus and icons) [136 ms]1659777821.0018177;top_libfredo6.rbe:171: in `open'
FredoTools 4.3a: Effective Load - #81659777821.0720754;top_libfredo6.rbe:171: in `open'
FredoTools 4.3a: Ruby files loaded [68 ms]1659777821.0804183;top_libfredo6.rbe:171: in `open'
Lib6Material: Loading body code from body_Lib6Material [4 ms]1659777821.1087255;top_libfredo6.rbe:171: in `open'
add Command >> FredoTools Launcher...1659777821.1106596;top_libfredo6.rbe:171: in `open'
add Command Angle Inspector1659777821.1128163;top_libfredo6.rbe:171: in `open'
add Command AutoReverseFaces1659777821.1148922;top_libfredo6.rbe:171: in `open'
add Command Color by Altitude1659777821.1164553;top_libfredo6.rbe:171: in `open'
add Command Color by Slope1659777821.1181555;top_libfredo6.rbe:171: in `open'
add Command Color Flat Mode1659777821.119647;top_libfredo6.rbe:171: in `open'
add Command Color Paint1659777821.1212366;top_libfredo6.rbe:171: in `open'
add Command Construct Face Normals1659777821.1233282;top_libfredo6.rbe:171: in `open'
add Command Convexify1659777821.1256363;top_libfredo6.rbe:171: in `open'
add Command Count Faces by Sides1659777821.1277225;top_libfredo6.rbe:171: in `open'
add Command CurviShear1659777821.12977;top_libfredo6.rbe:171: in `open'
add Command Divide Edges1659777821.1318834;top_libfredo6.rbe:171: in `open'
add Command Draw Along1659777821.1340015;top_libfredo6.rbe:171: in `open'
add Command Edge Inspector1659777821.1360934;top_libfredo6.rbe:171: in `open'
add Command Element Stats1659777821.138192;top_libfredo6.rbe:171: in `open'
add Command FaceTriangulator1659777821.1404064;top_libfredo6.rbe:171: in `open'
add Command Mark Vertices1659777821.1425476;top_libfredo6.rbe:171: in `open'
add Command Move Along1659777821.1447155;top_libfredo6.rbe:171: in `open'
add Command Remove Lonely Vertices1659777821.1468349;top_libfredo6.rbe:171: in `open'
add Command Report on Areas1659777821.1483846;top_libfredo6.rbe:171: in `open'
add Command Label with Areas1659777821.1504822;top_libfredo6.rbe:171: in `open'
add Command ReverseOrientFaces1659777821.1522555;top_libfredo6.rbe:171: in `open'
add Command Revert Curves1659777821.1544452;top_libfredo6.rbe:171: in `open'
add Command Solid Volume1659777821.1567695;top_libfredo6.rbe:171: in `open'
add Command ThruPaint1659777821.1585371;top_libfredo6.rbe:171: in `open'
add Command Informazioni Fredo Tools v4.3a...1659777821.1728668;top_libfredo6.rbe:171: in `open'
add Command Informazione Plugin [Sketchucation]...1659777821.1740627;top_libfredo6.rbe:171: in `open'
add Command Controlla aggiornamenti Plugins...1659777821.1757603;top_libfredo6.rbe:171: in `open'
add Command Modifica parametri di Default...1659777821.1768177;top_libfredo6.rbe:171: in `open'
add Command Traduzione Lingue...1659777821.263448;top_libfredo6.rbe:171: in `open'
FredoTools 4.3a: Startup (creating menus and icons) [190 ms]1659777821.2722695;top_libfredo6.rbe:171: in `open'
HoverSelect 1.5a: Effective Load - #91659777821.2924924;top_libfredo6.rbe:171: in `open'
HoverSelect 1.5a: Ruby files loaded [18 ms]1659777821.297239;top_libfredo6.rbe:171: in `open'
add Command Hover Select Edges1659777821.2992785;top_libfredo6.rbe:171: in `open'
add Command Informazioni HoverSelect v1.5a...1659777821.3032396;top_libfredo6.rbe:171: in `open'
add Command Informazione Plugin [Sketchucation]...1659777821.3041375;top_libfredo6.rbe:171: in `open'
add Command Controlla aggiornamenti Plugins...1659777821.3055997;top_libfredo6.rbe:171: in `open'
add Command Modifica parametri di Default...1659777821.3064806;top_libfredo6.rbe:171: in `open'
add Command Traduzione Lingue...1659777821.3119593;top_libfredo6.rbe:171: in `open'
HoverSelect 1.5a: Startup (creating menus and icons) [18 ms]1659777821.3206584;top_libfredo6.rbe:171: in `open'
JointPushPull 4.4e: Effective Load - #101659777821.3262935;top_libfredo6.rbe:171: in `open'
JointPushPull 4.4e: Bootstrap Ruby files loaded [4 ms]1659777821.335673;top_libfredo6.rbe:171: in `open'
add Command Quick Launcher...1659777821.3376372;top_libfredo6.rbe:171: in `open'
add Command Thickener1659777821.3393734;top_libfredo6.rbe:171: in `open'
add Command Joint Push Pull1659777821.341129;top_libfredo6.rbe:171: in `open'
add Command Round Push Pull1659777821.342861;top_libfredo6.rbe:171: in `open'
add Command Vector Push Pull1659777821.344577;top_libfredo6.rbe:171: in `open'
add Command Normal Push Pull1659777821.3462873;top_libfredo6.rbe:171: in `open'
add Command Extrude Push Pull1659777821.3480852;top_libfredo6.rbe:171: in `open'
add Command Follow Push Pull1659777821.3498316;top_libfredo6.rbe:171: in `open'
add Command Informazioni JointPushPull v4.4e...1659777821.3507373;top_libfredo6.rbe:171: in `open'
add Command License...1659777821.3516152;top_libfredo6.rbe:171: in `open'
add Command Trial Period Expiration...1659777821.357344;top_libfredo6.rbe:171: in `open'
add Command Informazione Plugin [Sketchucation]...1659777821.3597226;top_libfredo6.rbe:171: in `open'
add Command Controlla aggiornamenti Plugins...1659777821.3611848;top_libfredo6.rbe:171: in `open'
add Command Modifica parametri di Default...1659777821.362069;top_libfredo6.rbe:171: in `open'
add Command Traduzione Lingue...1659777821.413224;top_libfredo6.rbe:171: in `open'
JointPushPull 4.4e: Startup (creating menus and icons) [86 ms]1659777821.421949;top_libfredo6.rbe:171: in `open'
MoveAlignMe 1.2a: Effective Load - #111659777821.426346;top_libfredo6.rbe:171: in `open'
MoveAlignMe 1.2a: Bootstrap Ruby files loaded [3 ms]1659777821.4303312;top_libfredo6.rbe:171: in `open'
add Command Move - Pivot - Straighten1659777821.432269;top_libfredo6.rbe:171: in `open'
add Command Move and Glue1659777821.4339776;top_libfredo6.rbe:171: in `open'
add Command Informazioni MoveAlignMe v1.2a...1659777821.4389012;top_libfredo6.rbe:171: in `open'
add Command Informazione Plugin [Sketchucation]...1659777821.439845;top_libfredo6.rbe:171: in `open'
add Command Controlla aggiornamenti Plugins...1659777821.4413064;top_libfredo6.rbe:171: in `open'
add Command Modifica parametri di Default...1659777821.4421935;top_libfredo6.rbe:171: in `open'
add Command Traduzione Lingue...1659777821.4644544;top_libfredo6.rbe:171: in `open'
MoveAlignMe 1.2a: Startup (creating menus and icons) [37 ms]1659777821.4756064;top_libfredo6.rbe:171: in `open'
MrHide 1.6a: Effective Load - #121659777821.4834373;top_libfredo6.rbe:171: in `open'
MrHide 1.6a: Bootstrap Ruby files loaded [7 ms]1659777821.4958718;top_libfredo6.rbe:171: in `open'
add Command Quick Launcher1659777821.4974673;top_libfredo6.rbe:171: in `open'
add Command View Hidden Geometry1659777821.4989045;top_libfredo6.rbe:171: in `open'
add Command View Hidden Objects1659777821.500291;top_libfredo6.rbe:171: in `open'
add Command Draw Back Edges1659777821.501683;top_libfredo6.rbe:171: in `open'
add Command View Axes1659777821.5035517;top_libfredo6.rbe:171: in `open'
add Command View Component Axes1659777821.5050678;top_libfredo6.rbe:171: in `open'
add Command View Guides1659777821.506527;top_libfredo6.rbe:171: in `open'
add Command View Dimensions1659777821.5080168;top_libfredo6.rbe:171: in `open'
add Command View Text Labels1659777821.5095255;top_libfredo6.rbe:171: in `open'
add Command Display Shadows1659777821.5110574;top_libfredo6.rbe:171: in `open'
add Command Display Sun shading1659777821.5125182;top_libfredo6.rbe:171: in `open'
add Command View Fog1659777821.5139978;top_libfredo6.rbe:171: in `open'
add Command View Ground1659777821.5154166;top_libfredo6.rbe:171: in `open'
add Command View Sky1659777821.5169723;top_libfredo6.rbe:171: in `open'
add Command Color by Tag1659777821.5185745;top_libfredo6.rbe:171: in `open'
add Command Edge Visibility1659777821.5200028;top_libfredo6.rbe:171: in `open'
add Command Edge Profiles1659777821.521416;top_libfredo6.rbe:171: in `open'
add Command Draw Endpoints1659777821.522842;top_libfredo6.rbe:171: in `open'
add Command Edge Color By Material1659777821.524244;top_libfredo6.rbe:171: in `open'
add Command Edge Color By Axis1659777821.5256379;top_libfredo6.rbe:171: in `open'
add Command Hide similar instances1659777821.5270412;top_libfredo6.rbe:171: in `open'
add Command Hide Rest of the model1659777821.528457;top_libfredo6.rbe:171: in `open'
add Command Informazioni MrHide v1.6a...1659777821.5332236;top_libfredo6.rbe:171: in `open'
add Command Informazione Plugin [Sketchucation]...1659777821.5342171;top_libfredo6.rbe:171: in `open'
add Command Controlla aggiornamenti Plugins...1659777821.5356562;top_libfredo6.rbe:171: in `open'
add Command Modifica parametri di Default...1659777821.5366085;top_libfredo6.rbe:171: in `open'
add Command Traduzione Lingue...1659777821.652451;top_libfredo6.rbe:171: in `open'
MrHide 1.6a: Startup (creating menus and icons) [168 ms]1659777821.6611593;top_libfredo6.rbe:171: in `open'
ToolsOnSurface 2.5a: Effective Load - #131659777821.6690829;top_libfredo6.rbe:171: in `open'
ToolsOnSurface 2.5a: Bootstrap Ruby files loaded [7 ms]1659777821.6850967;top_libfredo6.rbe:171: in `open'
add Command Quick Launcher...1659777821.687485;top_libfredo6.rbe:171: in `open'
add Command Generic Tools on Surface1659777821.6888132;top_libfredo6.rbe:171: in `open'
add Command Line on Surface1659777821.6902533;top_libfredo6.rbe:171: in `open'
add Command Rectangle1659777821.6918726;top_libfredo6.rbe:171: in `open'
add Command Circle1659777821.6935656;top_libfredo6.rbe:171: in `open'
add Command Polygon1659777821.6957371;top_libfredo6.rbe:171: in `open'
add Command Ellipse1659777821.6975596;top_libfredo6.rbe:171: in `open'
add Command Parallelogram1659777821.6994553;top_libfredo6.rbe:171: in `open'
add Command Arc1659777821.7012951;top_libfredo6.rbe:171: in `open'
add Command Circle (3 Points)1659777821.7031078;top_libfredo6.rbe:171: in `open'
add Command Sector (Pie)1659777821.7049463;top_libfredo6.rbe:171: in `open'
add Command Offset on Surface1659777821.7067401;top_libfredo6.rbe:171: in `open'
add Command Free Hand on Surface1659777821.7086666;top_libfredo6.rbe:171: in `open'
add Command Edit Contours on Surface1659777821.7103713;top_libfredo6.rbe:171: in `open'
add Command Eraser on Surface1659777821.7118523;top_libfredo6.rbe:171: in `open'
add Command Informazioni Tools on Surface v2.5a...1659777821.712737;top_libfredo6.rbe:171: in `open'
add Command License...1659777821.7136042;top_libfredo6.rbe:171: in `open'
add Command Trial Period Expiration...1659777821.7186472;top_libfredo6.rbe:171: in `open'
add Command Informazione Plugin [Sketchucation]...1659777821.7195928;top_libfredo6.rbe:171: in `open'
add Command Controlla aggiornamenti Plugins...1659777821.721014;top_libfredo6.rbe:171: in `open'
add Command Modifica parametri di Default...1659777821.7218785;top_libfredo6.rbe:171: in `open'
add Command Traduzione Lingue...1659777821.8156009;top_libfredo6.rbe:171: in `open'
ToolsOnSurface 2.5a: Startup (creating menus and icons) [146 ms]1659777821.8244748;top_libfredo6.rbe:171: in `open'
VisuHole 1.4b: Effective Load - #141659777821.8285341;top_libfredo6.rbe:171: in `open'
VisuHole 1.4b: Bootstrap Ruby files loaded [3 ms]1659777821.8331802;top_libfredo6.rbe:171: in `open'
add Command VisuHole: Stencil1659777821.8352547;top_libfredo6.rbe:171: in `open'
add Command Informazioni VisuHole v1.4b...1659777821.836168;top_libfredo6.rbe:171: in `open'
add Command License...1659777821.8370469;top_libfredo6.rbe:171: in `open'
add Command Trial Period Expiration...1659777821.8414953;top_libfredo6.rbe:171: in `open'
add Command Informazione Plugin [Sketchucation]...1659777821.8425024;top_libfredo6.rbe:171: in `open'
add Command Controlla aggiornamenti Plugins...1659777821.8439815;top_libfredo6.rbe:171: in `open'
add Command Modifica parametri di Default...1659777821.8448694;top_libfredo6.rbe:171: in `open'
add Command Traduzione Lingue...1659777821.856961;top_libfredo6.rbe:171: in `open'
VisuHole 1.4b: Startup (creating menus and icons) [27 ms]1659777848.5419104;top_libfredo6.rbe:171: in `open'
LibFredo6: End of loading Cycle***-1659777848.655718;top_libfredo6.rbe:171: in `open'
Lib6ColorSpecDialog: Loading body code from body_Lib6ColorSpecDialog [8 ms] status = true1659777848.6649866;top_libfredo6.rbe:171: in `open'
Lib6Onglets: Loading body code from body_Lib6Onglets [8 ms] status = true1659777848.666665;top_libfredo6.rbe:171: in `open'
Lib6ColorScale: Loading body code from body_Lib6ColorScale [29 ms] status = true1659777848.7103868;top_libfredo6.rbe:171: in `open'
LordOfTheToolbars 2.2a: Ruby files loaded [165 ms]1659777848.7280338;top_libfredo6.rbe:171: in `open'
Lib6_txtmsg: Loading body code from body_Lib6_txtmsg [16 ms] status = true1659777848.7825856;top_libfredo6.rbe:171: in `open'
Lib6G6: Loading body code from body_Lib6G6 [53 ms] status = true1659777848.7919383;top_libfredo6.rbe:171: in `open'
LibFredo6: Loaded Binary C:/Users/robo/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU22/bin_body_Lib6G6.so1659777848.8168008;top_libfredo6.rbe:171: in `open'
Lib6Tool: Loading body code from body_Lib6Tool [16 ms] status = true1659777848.8180127;top_libfredo6.rbe:171: in `open'
Lib6Translate: Loading body code from body_Lib6Translate [25 ms] status = true1659777848.8472762;top_libfredo6.rbe:171: in `open'
Lib6RoundingProfiler: Loading body code from body_Lib6RoundingProfiler [15 ms] status = true1659777848.8485556;top_libfredo6.rbe:171: in `open'
Lib6Spline: Loading body code from body_Lib6Spline [29 ms] status = true1659777848.859474;top_libfredo6.rbe:171: in `open'
Lib6WebHtml: Loading body code from body_Lib6WebHtml [10 ms] status = true1659777848.8691103;top_libfredo6.rbe:171: in `open'
Lib6Algo: Loading body code from body_Lib6Algo [8 ms] status = true1659777848.8792436;top_libfredo6.rbe:171: in `open'
Lib6Contour: Loading body code from body_Lib6Contour [9 ms] status = true1659777848.8860703;top_libfredo6.rbe:171: in `open'
Lib6Offset3d: Loading body code from body_Lib6Offset3d [5 ms] status = true1659777848.8964381;top_libfredo6.rbe:171: in `open'
Lib6Transform: Loading body code from body_Lib6Transform [9 ms] status = true1659777848.9045694;top_libfredo6.rbe:171: in `open'
Lib6Mark: Loading body code from body_Lib6Mark [7 ms] status = true1659777848.9104576;top_libfredo6.rbe:171: in `open'
Lib6Vault: Loading body code from body_Lib6Vault [5 ms]1659777848.916615;top_libfredo6.rbe:171: in `open'
Lib6Marshall: Loading body code from body_Lib6Marshall [5 ms]1659777848.9322221;top_libfredo6.rbe:171: in `open'
Lib6CompManager: Loading body code from body_Lib6CompManager [15 ms]1659777848.9460337;top_libfredo6.rbe:171: in `open'
Lib6PathManager: Loading body code from body_Lib6PathManager [13 ms]1659777848.9552493;top_libfredo6.rbe:171: in `open'
Lib6Shortcuts: Loading body code from body_Lib6Shortcuts [7 ms]1659777848.9626634;top_libfredo6.rbe:171: in `open'
Lib6MonoFactory: Loading body code from body_Lib6MonoFactory [6 ms]1659777850.701963;top_libfredo6.rbe:171: in `open'
Lib6NativeManager: Loading body code from body_Lib6NativeManager [13 ms]1659777916.0953088;top_libfredo6.rbe:171: in `open'
Lib6ChromiumJS: Loading body code from body_Lib6ChromiumJS [4 ms]1659777916.1139123;top_libfredo6.rbe:171: in `open'
Lib6ChromiumWdlg: Loading body code from body_Lib6ChromiumWdlg [17 ms]1659779297.9428368;top_libfredo6.rbe:171: in `open'
Lib6Variator: Loading body code from body_Lib6Variator [6 ms] status = true1659779298.0459197;top_libfredo6.rbe:171: in `open'
FredoSpline 2.3a: Ruby files loaded [120 ms]1659779348.9734035;top_libfredo6.rbe:171: in `open'
Lib6PluginDialogs: Loading body code from body_Lib6PluginDialogs [10 ms]1659779348.9823189;top_libfredo6.rbe:171: in `open'
Lib6WebXTable: Loading body code from body_Lib6WebXTable [7 ms]
By chance, do you have Universal Importer installed or any other plugins by samuel_t?
If so, there is an incompatibility with LOTT, I am afraid, until Samuel updates his plugins.
Thanks, I solved it by uninstalling Universal Importer. Always punctual and precise. Without Fredo6 I would not be able to use Sketchup.
Hello there, Universal Importer plugin v1.1.8 is compatible with Lord Of The Toolbars plugin v2.2a
Hello fredo. Found an issue. If I set a palette shortcut to c, for example, when some plugins need VCB input, once I type c, this palette will popup untimely.
Hi Fredo,
I have whole heartly enbraced LOTT! It is exactly what I need to clean up my place of work!
The Vinette strip is incredibly fast as you hover over, which is exactly what it needs to be. I wonder possibly if there could a way of spacing out the icons / bigger area to hover over as when in the speed of the moment you can easily brush over the adjacent icon
Maybe a separator would work like the pallettes have
or
Bigger wider version of each icon? (I have small su icons enabled to save valuable space and i think that should still be on - what do you think?)
or
A Separate icon that act as a Vinette for each pallette you need and you can float or add to tool bar?what do you think?
Cheers
and Thanks AgainChris
You can click on the first 'dotted' button and choose menu (size of Vignettes). You can make them bigger or smaller.
OOOOH!!
Hello fredo. I have broken icons of plugins and scripts for which I used my pictures. Can they be restored somehow? I don't know how it happened ((
I do restore toolbars but does not help. All the pictures that I used are in place.
Hey Fredo.
I just brought your bundle and made a donation for all the great work you do. Before I install it I thought I would re arrange some of my LOTT pallets first. I have been using LOTT for a while now and love it, however the new pallets I have created will not disappear after I pick a tool or click outside of the pallet, or even if I press escape.. I have to either double click on the top of the pallet or click the red X to get them to close. Some, but not all of my older pallets continue to work fine and they close by themselves once I have clicked the icon for the tool I want to use. I have scrolled through the 'Default parameters' window but cant see if I am missing something or is this a bug. I have saved settings and closed and restarted SU but that did not help,
Any assistance you can offer would be greatly appreciated, I would like to resolve this issue before I install the bundle encase I have any other issues.
Could this be an issue with libFredo6 as this is the most recent update?
I have attached a screen shot, shortcuts A, B, D and X are the ones that are not working, A B and X are new, D is an old one that is also not working.SU2022
LOTT v2.2a
Libfredo6 13.2a Last updated on the 16 sep 22
Windows 11Thanks for your help
Mike
Could you open the Ruby Console before trying to close a palette, in case there is an error message displayed.
For shortcuts, I would suggest you do not select letters that are used by Sketchup native tools (such as A, B, D and X).
Hey Fredo
I have changed a shortcut key to SHIFT H but problem persists.
I opened the Ruby console and got no message when closing a pallet but I did get the attached message on start up of sketchup.
It means nothing to me, hopefully you can understand it.
Thanks for your helpMike
Fredo
I have cleaned out a few unused shortcut keys. There are now just 5 shortcuts for LOTT, and I noticed that the four that are not working properly also don't show up in the 'menu' window as shown by the screen shot. The only pallet that shows up in the orange custom shortcuts and the menu window is "Often used" and that was created a long time ago. the other 4 pallets and shortcuts were created yesterday and are the ones causing issuesCheers
The warning in the console is for TTLib. It is harmless and not related to LOTT.
I cannot reproduce the problem with shortcuts. In my environment, I can just define them and they work.
Do you have the latest version of LibFredo6 and LOTT installed?
Register LoginAdvertisement
