    Text in Arabic?
    5 Posts 4 Posters 7.9k Views 4 Watching
    • N
      nader1342
      Hi is it possible to create written text in Arabic or farsi in sketchup ?
      • TIGT
        If the font used has a broad range of characters [like Arial] then standard Text-Labels can be done in Arabic etc.
        I'd write the text in a text editor that supports the language, then copy+paste it into your text object in SketchUp.
        The character order and writing direction are kept.
        Unfortunately the equivalent in 3d-Text will do the same [with a suitable font], BUT sadly it reverses the writing direction from right>left to left>right, AND keeps the letter order so everything gets jumbled and messed up !
        If it were a short word, then reordering the letters manually could work, but it's a pain.
        السلام عليكم
        • R
          rv1974
          Nice workaround:
          http://www.arabic-keyboard.org/photoshop-arabic/
          Sadly I can't use Layout because of this imperfection 👿
          • N
            nlipovac
            You could write it down in Illustrator or similar vector software, export it to DXF and import it in SU.
            • N
              nader1342
              Hi guys I have a copy of the floor generator Sam D mitch but it doesn't work properly in sketchup.when i start using the plugin the attached txt file shows up instead of the main panel of the floor generator plugin. Ain't any one there could help and I can share my copy of the floor generator plugin with everyone. This is what shows up instead of the main panel of the floor generator plugin. I would be grateful if someone could help. Thanks.
              <html><body style='background-color:powderblue' ><form style='font-family:Arial;font-size:70%;color:black' > <fieldset>
              <legend style='font-size:125%;color:red'><b> Pattern </b></legend>
              <select onChange='patternchanged(value)'>
              <option value='Brick' >Brick</option>
              <option value='Tile' selected>Tile</option>
              <option value='Wood' >Wood</option>
              <option value='Tweed' >Tweed</option>
              <option value='Hbone' >Herringbone</option>
              <option value='BsktWv' >Basket Weave</option>
              <option value='HpScth1' >Hopscotch1</option>
              <option value='HpScth2' >HopScotch2</option>
              <option value='HpScth3' >HopScotch3</option>
              <option value='HpScth4' >HopScotch4</option>
              <option value='IrPoly' >Irregular Polygons</option>
              <option value='Hexgon' >Hexagons</option>
              <option value='Octgon' >Octagons</option>
              <option value='Wedge' >Wedges</option>
              <option value='I_Block' >I_Block</option>
              <option value='Diamonds' >Diamonds</option>
              <option value='Clapbrd' >Clapboard</option>
              <option value='Reset'>Reset</option>
              </select>
              <!-- Pattern Icons -->
              				<img src='C:/Users/NADER PEZESHKAN/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/FG_Icons/Tile.jpg' align='top'/>
              			</fieldset>
              		<fieldset>
              			<legend style='font-size:125%;color:red'><b> Size </b></legend>
              			<table style='font-size:100%'>
              				<tr><td align='right' width=54>Length:</td>
              				<td><input type='text' name='BTL' value='300.0mm' size=4 onChange='optionchanged(name,value)' /></td>
              				<tr><td align='right'>Width:</td>
              				<td><input type='text' name='BTW' value='300.0mm' size=4 onChange='optionchanged(name,value)' /></td>
              				<tr><td align='right' width=54>Gap Width:</td><td>
              				<input type='text' name='BGW' value='6.0mm' size=4 onChange='optionchanged(name,value)' /></td></tr>
              				<tr><td align='right' width=54>Gap Depth:</td><td>
              				<input type='text' name='BGD' value='3.0mm' size=4 onChange='optionchanged(name,value)' /></td><td>
              				<input type='checkbox' name='FWT' value='Yes' checked onClick='optionchanged(name,value)'>Fixed
              				</td></tr>
              				<tr><td align='right' width=54>% Offset:</td>
              				<td><input type='text' name='R2R' value='0.0' size=4 onChange='optionchanged(name,value)' /></td></tr>
              			</table>
              		</fieldset>
              		<fieldset>
              			<legend style='font-size:125%;color:red'><b> Options </b></legend>
              			<select name='ORG' style='width:90px' onChange='optionchanged(name,value)'>
              				<option value='Corner' selected>Corner</option>
              				<option value='Center' >Center</option>
              			</select> : Grid Origin<br>
              			<select name='ROT' style='width:90px' onChange='optionchanged(name,value)'>
              				<option value='0' selected>0</option>
              				<option value='45' >45</option>
              				<option value='90' >90</option>
              			</select> : Grid Rotation<br>
              			<select name='MAT' style='width:90px' onChange='optionchanged(name,value)'>
              				<option value='Current' selected>Current</option>
              				<option value='Rand_Clr' >Rand_Clr</option>
              				<option value='Rand_Tex' >Rand_Tex</option><br>
              			</select> : Material<!--
              			&nbsp&nbsp<button id='RTS' onclick='ChangeSource(id)'>Source</button>--><br><hr>
              			<input type='text' name='RDS' value='0' size=2 onChange='optionchanged(name,value)'/> : Random Seed<br><hr>
              			<input type='text' name='TSZ' value='0.0mm' size=5 onChange='optionchanged(name,value)'/> : Texture Size (w,h)<br>
              			<input type='checkbox' name='ATE' value='Yes'  onClick='optionchanged(name,value)'>Align Texture to Longest Edge<br>
              			<input type='checkbox' name='WIG' value='Yes'  onClick='optionchanged(name,value)'>Random Position Texture </input>
              			Inc: <input type='text' name ='RTI' value='1.0mm' size=3 onchange='optionchanged(name,value)'/>
              			--><br>
              			<select name='WAG' style='width:60px' onChange='optionchanged(name,value)'>
              				<option value='No' selected>No</option>
              				<option value='30' >30</option>
              				<option value='180' >180</option>
              				<option value='Rand' >Rand</option>
              			</select> : Random Rotation<br>
              			<hr>
              			<input type='checkbox' name='WOB' value='Yes'  onClick='optionchanged(name,value)'/>Random Imperfections<br>
              			Min:<input type='text' name='RIn' value='0.0mm' size=4 onChange='optionchanged(name,value)'/>
              			Max:<input type='text' name='RIx' value='3.0mm' size=4 onChange='optionchanged(name,value)'/> <br>
              			<input type='checkbox' name='BVL' value='Yes'  onClick='optionchanged(name,value)'/>Add Bevel to Tile<br>
              			Size:<input type='text' name='BVS' value='6.0mm' size=4 onChange='optionchanged(name,value)'/><br>
              			<input type='checkbox' name='CBF' value='Yes'  onClick='optionchanged(name,value)'/>Create Behind Face<br>
              			<input type='checkbox' name='CIG' value='Yes'  onClick='optionchanged(name,value)'/>Create Individual Groups<br>
              		</fieldset>
              		</form>
              </body></html> <script type='text/javascript'>
              function patternchanged(value)
              window.location='skp:PatternChanged@'+value;
              function optionchanged(name,value)
              window.location='skp:OptionChanged@'+name+'='+value;
              function ChangeSource()
              window.location='skp:ChangeSource@';
              </script>
