Text in Arabic?
Hi is it possible to create written text in Arabic or farsi in sketchup ?
If the font used has a broad range of characters [like Arial] then standard Text-Labels can be done in Arabic etc.
I'd write the text in a text editor that supports the language, then copy+paste it into your text object in SketchUp.
The character order and writing direction are kept.Unfortunately the equivalent in 3d-Text will do the same [with a suitable font], BUT sadly it reverses the writing direction from right>left to left>right, AND keeps the letter order so everything gets jumbled and messed up !
If it were a short word, then reordering the letters manually could work, but it's a pain.السلام عليكم
Nice workaround:
Sadly I can't use Layout because of this imperfection
You could write it down in Illustrator or similar vector software, export it to DXF and import it in SU.
Hi guys I have a copy of the floor generator Sam D mitch but it doesn't work properly in sketchup.when i start using the plugin the attached txt file shows up instead of the main panel of the floor generator plugin. Ain't any one there could help and I can share my copy of the floor generator plugin with everyone. This is what shows up instead of the main panel of the floor generator plugin. I would be grateful if someone could help. Thanks.
<html><body style='background-color:powderblue' ><form style='font-family:Arial;font-size:70%;color:black' > <fieldset>
<legend style='font-size:125%;color:red'><b> Pattern </b></legend>
<select onChange='patternchanged(value)'>
<option value='Brick' >Brick</option>
<option value='Tile' selected>Tile</option>
<option value='Wood' >Wood</option>
<option value='Tweed' >Tweed</option>
<option value='Hbone' >Herringbone</option>
<option value='BsktWv' >Basket Weave</option>
<option value='HpScth1' >Hopscotch1</option>
<option value='HpScth2' >HopScotch2</option>
<option value='HpScth3' >HopScotch3</option>
<option value='HpScth4' >HopScotch4</option>
<option value='IrPoly' >Irregular Polygons</option>
<option value='Hexgon' >Hexagons</option>
<option value='Octgon' >Octagons</option>
<option value='Wedge' >Wedges</option>
<option value='I_Block' >I_Block</option>
<option value='Diamonds' >Diamonds</option>
<option value='Clapbrd' >Clapboard</option>
<option value='Reset'>Reset</option>
</select>
<!-- Pattern Icons --><img src='C:/Users/NADER PEZESHKAN/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/FG_Icons/Tile.jpg' align='top'/> </fieldset> <fieldset> <legend style='font-size:125%;color:red'><b> Size </b></legend> <table style='font-size:100%'> <tr><td align='right' width=54>Length:</td> <td><input type='text' name='BTL' value='300.0mm' size=4 onChange='optionchanged(name,value)' /></td> <tr><td align='right'>Width:</td> <td><input type='text' name='BTW' value='300.0mm' size=4 onChange='optionchanged(name,value)' /></td> <tr><td align='right' width=54>Gap Width:</td><td> <input type='text' name='BGW' value='6.0mm' size=4 onChange='optionchanged(name,value)' /></td></tr> <tr><td align='right' width=54>Gap Depth:</td><td> <input type='text' name='BGD' value='3.0mm' size=4 onChange='optionchanged(name,value)' /></td><td> <input type='checkbox' name='FWT' value='Yes' checked onClick='optionchanged(name,value)'>Fixed </td></tr> <tr><td align='right' width=54>% Offset:</td> <td><input type='text' name='R2R' value='0.0' size=4 onChange='optionchanged(name,value)' /></td></tr> </table> </fieldset> <fieldset> <legend style='font-size:125%;color:red'><b> Options </b></legend> <select name='ORG' style='width:90px' onChange='optionchanged(name,value)'> <option value='Corner' selected>Corner</option> <option value='Center' >Center</option> </select> : Grid Origin<br> <select name='ROT' style='width:90px' onChange='optionchanged(name,value)'> <option value='0' selected>0</option> <option value='45' >45</option> <option value='90' >90</option> </select> : Grid Rotation<br> <select name='MAT' style='width:90px' onChange='optionchanged(name,value)'> <option value='Current' selected>Current</option> <option value='Rand_Clr' >Rand_Clr</option> <option value='Rand_Tex' >Rand_Tex</option><br> </select> : Material<!--   <button id='RTS' onclick='ChangeSource(id)'>Source</button>--><br><hr> <input type='text' name='RDS' value='0' size=2 onChange='optionchanged(name,value)'/> : Random Seed<br><hr> <input type='text' name='TSZ' value='0.0mm' size=5 onChange='optionchanged(name,value)'/> : Texture Size (w,h)<br> <input type='checkbox' name='ATE' value='Yes' onClick='optionchanged(name,value)'>Align Texture to Longest Edge<br> <input type='checkbox' name='WIG' value='Yes' onClick='optionchanged(name,value)'>Random Position Texture </input> <!-- Inc: <input type='text' name ='RTI' value='1.0mm' size=3 onchange='optionchanged(name,value)'/> --><br> <select name='WAG' style='width:60px' onChange='optionchanged(name,value)'> <option value='No' selected>No</option> <option value='30' >30</option> <option value='45' >45</option> <option value='90' >90</option> <option value='180' >180</option> <option value='Rand' >Rand</option> </select> : Random Rotation<br> <hr> <input type='checkbox' name='WOB' value='Yes' onClick='optionchanged(name,value)'/>Random Imperfections<br> <!-- Min:<input type='text' name='RIn' value='0.0mm' size=4 onChange='optionchanged(name,value)'/> Max:<input type='text' name='RIx' value='3.0mm' size=4 onChange='optionchanged(name,value)'/> <br> --> <input type='checkbox' name='BVL' value='Yes' onClick='optionchanged(name,value)'/>Add Bevel to Tile<br> <!-- Size:<input type='text' name='BVS' value='6.0mm' size=4 onChange='optionchanged(name,value)'/><br> --> <input type='checkbox' name='CBF' value='Yes' onClick='optionchanged(name,value)'/>Create Behind Face<br> <input type='checkbox' name='CIG' value='Yes' onClick='optionchanged(name,value)'/>Create Individual Groups<br> </fieldset> </form></body></html> <script type='text/javascript'>
function patternchanged(value)
window.location='skp:PatternChanged@'+value;
function optionchanged(name,value)
window.location='skp:OptionChanged@'+name+'='+value;
function ChangeSource()
window.location='skp:ChangeSource@';
</script>
