    Malicious File Detected
    Scheduled Pinned Locked Moved SUbD
    renderpluginsextensions
    3 Posts 2 Posters 5.9k Views 2 Watching
    • SJS66S Offline
      SJS66
      My Bitdefender Total Security just quarantined then disinfected the file
      TT_SUbD\libraries\2.1.7.0\2.7\win64\SUbD.so
      because it detected a threat
      Gen:Suspicious.Cloud.4.!y4@auTVb9ki
      Tried re-installing the plugin again it but it gets disinfected by Bitdefender every time & deletes the win64 folder in the "stages" folder containing the SubD.so file.
      So I can't install it in SU without getting the "Oops, something went wrong" error submit coming up, which I submitted with similar details.
      Anyone else had issues with latest version of SubD & SU 2021 (Win64)?
      • SJS66S Offline
        SJS66
        So I'm no longer getting the Malicious File Detected message, but, when I install SubD-2.1.7 into S.U. 2021, I'm getting the following message & the SubD Tools aren't available, although it says it's installed in Extension Manager. Basically it doesn't work.
        Error message attached as a text file.
        Error text when opening SketchUp Pro 2021 if SubD-2.1.7 is installed.
          Bitdefender started reporting false positives for SUbD last week. I've submitted a False Positive report to them, hoping they'll update their definitions soon.
          In regard to your recent post: can you check if C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/TT_SUbD/libraries/2.1.7.0/2.7/win64/SUbD.so exists on your machine?
          If it does, and you still get this error, can you ZIP up the C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/TT_SUbD folder and send it to me please?
          (False positives from AV software is such a pain to clean up.)
